Configure 3 Gang ZigBee Wireless Switch
I’m new to Home Assistant and have a Tuya Switch with 3 Buttons.
It is recognized by the Tuya add-on. But I can’t configure the buttons. The switch is said as unsupported.
Is it planned to add support? If not, is there a how-to and an API Reference how to contribute?
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2022.2.7",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.9.7",
    "docker": true,
    "arch": "x86_64",
    "timezone": "Europe/Berlin",
    "os_name": "Linux",
    "os_version": "5.10.98",
    "supervisor": "2022.01.1",
    "host_os": "Home Assistant OS 7.4",
    "docker_version": "20.10.9",
    "chassis": "vm",
    "run_as_root": true
  "custom_components": {
    "spotcast": {
      "version": "v3.6.25",
      "requirements": [
        "spotify_token==1.0.0"
    "hacs": {
      "version": "1.22.0",
      "requirements": [
        "aiogithubapi>=21.11.0"
  "integration_manifest": {
    "domain": "tuya",
    "name": "Tuya",
    "documentation": "https://www.home-assistant.io/integrations/tuya",
    "requirements": [
      "tuya-iot-py-sdk==0.6.6"
    "dependencies": [
      "ffmpeg"
    "codeowners": [
      "@Tuya",
      "@zlinoliver",
      "@METISU",
      "@frenck"
    "config_flow": true,
    "iot_class": "cloud_push",
    "dhcp": [
        "macaddress": "105A17*"
        "macaddress": "10D561*"
        "macaddress": "1869D8*"
        "macaddress": "381F8D*"
        "macaddress": "508A06*"
        "macaddress": "68572D*"
        "macaddress": "708976*"
        "macaddress": "7CF666*"
        "macaddress": "84E342*"
        "macaddress": "D4A651*"
        "macaddress": "D81F12*"
    "is_built_in": true
  "data": {
    "endpoint": "https://openapi.tuyaeu.com",
    "auth_type": 0,
    "country_code": "49",
    "app_type": "smartlife",
    "mqtt_connected": true,
    "disabled_by": null,
    "disabled_polling": false,
    "name": "3 Gang ZigBee Scene Switch",
    "model": "",
    "category": "wxkg",
    "product_id": "gbm10jnj",
    "product_name": "3 Gang ZigBee Scene Switch",
    "online": true,
    "sub": true,
    "time_zone": "+01:00",
    "active_time": "2022-02-12T11:17:18+00:00",
    "create_time": "2022-02-12T11:17:18+00:00",
    "update_time": "2022-02-12T11:17:18+00:00",
    "function": {},
    "status_range": {
      "switch1_value": {
        "type": "Enum",
        "value": {
          "range": [
            "single_click",
            "double_click",
            "long_press"
      "switch_mode2": {
        "type": "Enum",
        "value": {
          "range": [
            "click",
            "double_click",
            "press"
      "switch_mode3": {
        "type": "Enum",
        "value": {
          "range": [
            "click",
            "double_click",
            "press"
      "battery_percentage": {
        "type": "Integer",
        "value": {
          "unit": "%",
          "min": 0,
          "max": 100,
          "scale": 0,
          "step": 1
    "status": {
      "switch1_value": "single_click",
      "switch_mode2": "click",
      "switch_mode3": "click"
    "home_assistant": {
      "name_by_user": null,
      "disabled": false,
      "entities": []
Also interested, but mine is the 4 gang version.
I’m a dev and can help implementing it too. Any similar device already implemented to use as a guide?
