Configure Backup HTTP URL for local access
Many times HTTPS stops working, so I need a backup local URL. This also stopped working. When I configure a local URL, I get this error message;
Invalid local network URL
You have configured an HTTPS certificate in Home Assistant. This means that your internal URL needs to be set to a domain covered by the certificate.
How are you suppose to setup a local fall back method? This used to work.
You can still access your local instance at any time despite the warning.
Go to httpS://yourIP:8123 in your browser. Click through the warning (in chrome, click advanced > proceed [unsafe]).
You’ll be redirected to the http version of the site and get a certificate error in the address bar, but it’ll work just fine
I tried replacing my certificate. Did something wrong, there was no way it would accept any connection. The installation was ‘bricked’.
Not on any port combination/https/http/accepting Certificate warnings.
I had to go via console.
But isn’t there any type of fix?
