Hi everyone,
i’m trying to create a multi agent system which can create dynamically cleaner plans for my roborock robot.
The system can either call existing automations through a web call or it can write the yaml file to create a new automation.
Now i wonder if it is possible to create a new automation configuration through the Api (aka Web-Service Call) in Home Assistant.
Any input appreciated.
Found the solution.
A Python program like this cand create automations:
import requests
def create_automation():
# Home Assistant details
base_url = ":8123" # Replace with your Home Assistant URL
access_token = # Replace with your token
api_endpoint = f"{base_url}/api/config/automation/config/my_automation_id"
# Automation configuration
automation_config = {
"alias": "Turn on Lights at Sunset",
"trigger": [
"platform": "sun",
"event": "sunset",
"action": [
"service": "light.turn_on",
"target": {
"entity_id": "light.living_room"
"mode": "single"
# Headers for authentication
headers = {
"Authorization": f"Bearer {access_token}",
"Content-Type": "application/json"
# Send the request
response = requests.post(api_endpoint, json=automation_config, headers=headers)
# Check response
if response.status_code == 200:
print("Automation created successfully!")
else:
print(f"Failed to create automation: {response.status_code}, {response.text}")
def main():
print("Creating Home Assistant automation...")
create_automation()
if __name__ == "__main__":
main()
shane0802
(Shane0802)
July 28, 2025, 1:06am
4
Do you have the solution to create scripts or scenes?
Thank you
