“The radio module firmware on your Home Assistant Connect ZBT-1 could not be determined. Make sure that no other integration or add-on is currently trying to communicate with the device. If Home Assistant OS is running in a virtual machine or in Docker, please make sure that the permissions for the device are set correctly.”
No Idea how solve this issue.
Maybe one you guys can help.
Sorry I had to get some lunch but the logs are interesting… seems like the device is changing, almost like it’s being unplugged and plugged in again
switching between ttyUSB0 and ttyUSB1
ie usb 2-1 and usb 2-2
Can you ensure that the device is static in a single dedicated USB slot ?
2025-01-21 21:03:11.017 homeassistant kernel: usb 2-2: new full-speed USB device number 3 using xhci_hcd
2025-01-21 21:03:11.176 homeassistant kernel: usb 2-2: New USB device found, idVendor=10c4, idProduct=ea60, bcdDevice= 1.00
2025-01-21 21:03:11.176 homeassistant kernel: usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
2025-01-21 21:03:11.177 homeassistant kernel: usb 2-2: Product: Home Assistant Connect ZBT-1
2025-01-21 21:03:11.200 homeassistant kernel: usb 2-2: Manufacturer: Nabu Casa
2025-01-21 21:03:11.202 homeassistant kernel: usb 2-2: SerialNumber: c6baf77c893aef1196602e1455516304
2025-01-21 21:03:11.207 homeassistant kernel: cp210x 2-2:1.0: cp210x converter detected
2025-01-21 21:03:11.210 homeassistant kernel: usb 2-2: cp210x converter now attached to ttyUSB1
No Problem.
Thank you.
That’s the HOST Protocol right?
Might be possible that I changed the stick from the back to the front.
I just restarted the system after update.
And there is no ZBT to see. I will unplug it and put it in again. …
I took it out and back again.
Can I send u the log later? Im at the train now.
But it not possible that it is a time zone problem? I saw the was 16 … when it was 17…
I use my fritz!box as time server and in the settings of HA is Berlin selected.
You need to keep the ZBT plugged in, never unplug it whilst HA is running.
Keep it plugged into the same USB slot on the host. Reboot HAOS and see how you get on
