Hello. I’m relatively new to ESPHome and Home Assistant. I’m trying to setup a LILYGO T3 LoRa32 V1.6.1 to read data from AcuRite temperature sensors. I’m using the custom component from https://github.com/swoboda1337/acurite-esphome/.
I’m confused about how to setup the remote_receiver block. How do I know which pin assignment to use there? Currently it’s set to GPIO32, but I only have that value set because that’s what’s shown in the sample config from the custom component’s website. As far as I can tell, my LoRa32 doesn’t have a GPIO32 pin.
Also, how do I know which settings to use in the sx127x block (e.g., modulation, bandwidth, etc.)?
Thank you.
substitutions:
board: ttgo-lora32-v21
spi_clk_pin: GPIO5
spi_mosi_pin: GPIO27
spi_miso_pin: GPIO19
sx127x_cs_pin: GPIO18
sx127x_rst_pin: GPIO23
sx127x_dio0_pin: GPIO26
remote_receiver_pin: GPIO32
esphome:
esp32:
board: ${board}
framework:
type: esp-idf
logger:
level: INFO
api:
encryption:
key: "!secret api_encryption_key"
ota:
- platform: esphome
password: "!secret otapassword"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: ${name}
password: "!secret wifi_ap_password"
captive_portal:
spi:
clk_pin: ${spi_clk_pin}
mosi_pin: ${spi_mosi_pin}
miso_pin: ${spi_miso_pin}
sx127x:
cs_pin: ${sx127x_cs_pin}
rst_pin: ${sx127x_rst_pin}
dio0_pin: ${sx127x_dio0_pin}
frequency: 433920000
modulation: OOK
rx_start: true
bandwidth: 50_0kHz
packet_mode: false
bitsync: true
rx_floor: -90
remote_receiver:
pin: ${remote_receiver_pin}
dump: all
external_components:
- source: github://swoboda1337/acurite-esphome
acurite:
