Hi there,
I was wondering if I can use ESPHome with Seeed’s mmwave Human Detection Kit to output 3.3V on the A0 pin of the Grove Analog Interface when Existence Energy exceeds 10. I also want to be able to set a “calm down” time of 30 secs - so when existence energy exceeds 10, A0 will output 3.3V and won’t output any voltage for the next 30 secs, even if Existence Energy exceeds 10 again within the 30 sec period.
Here’s the esphome yaml config for the human detection kit:
substitutions:
friendly_name: "SeeedStudio mmWave Kit"
esphome:
friendly_name: "${friendly_name}"
name_add_mac_suffix: true
project:
version: "3.0"
platformio_options:
board_build.flash_mode: dio
board_build.mcu: esp32c3
# external_components:
# - source: github://limengdu/mmwave-kit-external-components@main
# refresh: 0s
esp32:
board: esp32-c3-devkitm-1
variant: esp32c3
framework:
type: esp-idf
# Enable logging
logger:
hardware_uart: USB_SERIAL_JTAG
level: DEBUG
# Enable Home Assistant API
api:
ota:
- platform: esphome
wifi:
ap:
ssid: "seeedstudio-mr24hpc1"
captive_portal:
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# Sets up the improv via serial client for Wi-Fi provisioning.
# Handy if your device has a usb port for the user to add credentials when they first get it.
# improv_serial: # Commented until improv works with usb-jtag on idf
uart:
baud_rate: 115200
rx_pin: 4
tx_pin: 5
parity: NONE
stop_bits: 1
seeed_mr24hpc1:
text_sensor:
- platform: seeed_mr24hpc1
heart_beat:
product_model:
product_id:
hardware_model:
hardware_version:
keep_away:
name: "Active Reporting Of Proximity"
motion_status:
name: "Motion Information"
custom_mode_end:
name: "Custom Mode Status"
binary_sensor:
has_target:
name: "Presence Information"
custom_presence_of_detection:
name: "Static Distance"
movement_signs:
name: "Body Movement Parameter"
custom_motion_distance:
name: "Motion Distance"
custom_spatial_static_value:
custom_spatial_motion_value:
custom_motion_speed:
custom_mode_num:
name: "Current Custom Mode"
switch:
underlying_open_function:
name: Underlying Open Function Info Output Switch
button:
restart:
custom_set_end:
name: "End Of Custom Mode Settings"
select:
scene_mode:
unman_time:
name: "Time For Entering No Person State (Standard Function)"
existence_boundary:
name: "Existence Boundary"
motion_boundary:
name: "Motion Boundary"
number:
sensitivity:
custom_mode:
existence_threshold:
name: "Existence Energy Threshold"
motion_threshold:
name: "Motion Energy Threshold"
motion_trigger:
name: "Motion Trigger Time"
motion_to_rest:
name: "Motion To Rest Time"
custom_unman_time:
name: "Time For Entering No Person State (Underlying Open Function)"
How would I need to modify this to achieve the desired result?
Thanks a lot for your help.
