To begin with enable LG Connect Apps feature in Network settings of the TV
I have been through all the settings of this TV and LG connect apps is not mentioned anywhere. There is a “Mobile TV” option which is ticked and I can access the TV from my phone using the LG app.
this is the code I used
webostv:
host: 192.168.0.135
It seems to work fine and I get the option to configure the TV in notifications.
However when I click “start pairing requests” nothing happens on the TV.
I have the IP address of the TV fixed and double checked it. Any other ideas?
make sure you have these both
wake_on_lan
media_player
Also make sure you have assigned a Static IP to the TV. because if your router changes its IP… then you have to keep changing it… also they like to work better with LAN cable. my older one is with lan but the newer one its on wifi
