is it possible to configure the default lovelace ui (moving around some objects) but leaving the automatic entity generation active? I created a second page and I hoped the default page with automatic management is still on. Now I have the problem for example that entities won’t be generated automatically. One case are the switches if shelly firmware updates are available. I cannot see them and when I create them manually I will get an “missing entity” error when I start the firmware update.
I created a second dashboard and took control of it. I did not take control of the first, default dashboard. All new entities that I create are automatically added to the default dashboard (and have to be manually added to the second dashboard). That’s how it’s supposed to work. A dashboard maintains its “auto-generation” until you take control of it.
