In the past I have used RaspberryPIs to run NUT service for UPSs connected to the Pi via USB. Fot this I just needed the NUT Integration
Now I want to integrate an Eaton 5PX Gen2 UPS using SNMP. The 5PX has a network interface card
On the 5PX I have enabled SNMP v3 and setup a user with no auth, no priv authentication
My understanding is that I need to use the NUT add-in to interface with the SNMP service. I have installed the add-in but I am confused how to configure the device section. I tried added some config values (eg. snmp_version=v3) but when I start the addon, the logs complain that I have not set a username
Does anyone have an example of how to setup the device fields for and SNMP integration?
