i have two DALI-Tunable White Panels in my room with a DALI-Matter Bridge (Matter to DALI Bridge 💡 M2D Bridge).
Roughly it works like it should. I can dim and change the colour-temp.
Now to my …“problems”.
Is it possible to change the slider for changing colour-temp and dim-level?
The slider for dimming goes from 1 to 100% (what else ) If i set it to 1% it switches on on lowest level but the next change in brightness is at 45%. So from 1 to 44% it’s always the same level and from 45% to 100% there is a “normal” dimming until maximum.
So when the ruler starts at 44% it would be perfect…
For the colour-temp…the ruler goes from 2700K to 6500K. But the Panels range is from 2700K to 5700K. Can i adjust this also?
Is it possible to “split” the settings card for this up? At the moment i have this on my overview
When i click on it i’ve got the slider for the brightness and i can click on the colour-temp icon to get the other slider.
i want to have one slider for the brightness and one for the colour-temp on my overview
There are no entities to select in the settings of the device (or i didn’t find them…).
Thanks for your help
Paddie
