Configuring Teison CT clamp
Hi all! I recently had a Teison EV charger installed, along with the CT clamp.
I got the charger talking to HA via OCPP, but for the life of me I can’t work out how to get the CT clamp happening. It talks to the Teison app but I’m struggling to get the data into HA.
I’ve installed this component: GitHub - volski/teison_ct_clamp_hassio · GitHub using the default host (0.0.0.0) and port (12345) as per the documentation. Not sure if that’s default in the sense that it’s “usually correct” or if it should be set to something else.
Has anyone else out there managed to get this working at all?
Thanks for your help!
The only thing I know about your set up is from the github link. are you seeing any or all of the sensor in *Settings–>Developer tools–>states?
Thank you, yes it’s rather uncommon which is just my luck!
I am seeing the sensors in States, but they’re just reading unavailable. I’ll have a poke around the clamp unit with wireshark and see if I can find out how on earth it sends its data, and if that clarifies anything.
I am having the same issue no data coming through
