Hello all, After setting up a raspberry pi using the all-in-one installer, I noticed in the logs that Home Assistant, had found and tried to log on to the AlarmDecoder Webapp running another raspberry pi, However I cannot find where to enter the correct password that woudl allow Home Assistant to log in sucesfully
Hi GWayneC,
I am using AlarmDecoder too and I am stuck. I really don’t know how to get it integrated with HA. I managed to do this:
Using a Restful sensor. But I cannot talk to the API at all to get the status out. I can see the status changing when something changes on the zones that I have deifined, but it is pretty much it.
Any luck on your side on getting the AlarmDecoder to work with HA? Any guidance or help is highly appreciated.
Thanks,
Julio C.
No, not yet, I haven’t had the time. I do know from the logs, that Home Assistant is trying to connect, but is getting access denied, I was hoping to find out where thsi is happening so that I could supply the correct password
