So I’m following Keaton Taylor’s setup for Alexa Actionable Notifications https://github.com/keatontaylor/alexa-actions/wiki/FirstAction, and when I ask “Alexa, open custom actions”, she worked flawlessly. But now I’m stuck. I created my first of 3 notifications to tell me when my garage doors are up (PS - I have created 3 separate automations and would love to learn how to reduce this code…if possible). The automation to recognize if the door sensor is open works, or I think it works for I see it in the log history. It activates the script file, and then stops. She never asks me anything. I know that I’ve got some rookie mistake going on in my files, but I can’t see the forest because of the trees. Would love it, if you guys could take a quick peak and give me some guidance. Here’s my files…
located within my config.yaml file…
input_text:
alexa_actionable_notification:
name: Alexa Actionable Notification Holder
max: 255
initial: '{"text": "This is a test of the alexa actions custom skill. Did it work?", "event": "actionable.skill.test"}'
group: !include groups.yaml
automation: !include_dir_merge_list automations_folder
script: !include scripts.yaml
scene: !include scenes.yaml
/config/automations_folder/garage_door_1_open.yaml
- alias: Garage_Door_1_Open
- platform: state
entity_id: binary_sensor.wyzesense_7791dc8e
to: 'on'
- platform: time
at:
- '21:00:00'
- '22:30:00'
- service: script.activate_alexa_actionable_notification
data_template:
text: 'It is 9pm and garage door one is still open, would you like me to close it?'
event_id: 'actionable_notification_garage_1_left_open'
alexa_device: 'media_player.Living_Room_Dot'
/config/automations_folder/garage_door_1_close.yaml
- alias: Close_garage_door_1
platform: event
event_type: alexa_actionable_notification
event_data:
event_id: actionable_notification_garage_1_left_open
event_response_type: ResponseYes
- service: switch.turn_on
entity_id: switch.sonoff_10002a657b_1
/config/scripts.yaml
# Keaton's Alexa Actionable Notifications https://github.com/keatontaylor/alexa-actions/wiki/CustomSkill
activate_alexa_actionable_notification:
description: 'Activates an actionable notification on a specific echo device'
fields:
text:
description: 'The text you would like alexa to speak.'
example: 'What would you like the thermostat set to?'
event_id:
description: 'Correlation ID for event responses'
example: 'ask_for_temperature'
alexa_device:
description: 'Alexa device you want to trigger'
example: 'media_player.Living_Room_Dot'
sequence:
- service: input_text.set_value
data_template:
entity_id: input_text.alexa_actionable_notification
value: '{"text": "{{ text }}", "event": "{{ event_id }}"}'
- service: media_player.play_media
data_template:
entity_id: "{{ alexa_device }}"
media_content_type: skill
media_content_id: 'amzn1.ask.skill.xxxxxxxxxxxxxx'
This is the ERROR that I get for each door, but I pulled Garage Door 1 from homeassistant.log
2020-08-16 21:15:00 ERROR (MainThread) [homeassistant.components.script.activate_alexa_actionable_notification] activate_alexa_actionable_notification: Error executing script. Service not found for call_service at pos 2: Unable to find service media_player/play_media
2020-08-16 21:15:00 ERROR (MainThread) [homeassistant.components.automation.garage_door_1_open] Garage_Door_1_Open: Error executing script. Service not found for call_service at pos 1: Unable to find service media_player/play_media
2020-08-16 21:15:00 ERROR (MainThread) [homeassistant.components.automation.garage_door_1_open] While executing automation automation.garage_door_1_open
This is the HACS integration I have loaded…
I’m stuck wondering what I’m doing wrong, and hoped that someone would see this and tell me the stupid thing is…?
Thanks in advance
