Confusion - Command Line YAML configuration has moved
All, I am very confused as to what actually needs command_line: and what does not, can anyone point me in the right direction?.
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - IP
group: !include groups.yaml
influxdb:
  host: IP
  port: 8086
  database: database
  username: username
  password: password
  max_retries: 3
  default_measurement: state
############### LINKS TO COMMON ITEMS ########################
script: !include scripts.yaml
scene: !include scenes.yaml
#alert: !include alerts.yaml
########################## MQTT SETUP ########################
mqtt:
    - name: "Garage Temp Sensor"
      state_topic: "garage/sensor/temperature"
      unit_of_measurement: "°C"
      device_class: "temperature"
    - name: "Sump Level Sensor"
      state_topic: "sump/sensor/avglevel"
      unit_of_measurement: "%"
    - name: "HotTub Water Temp Sensor"
      state_topic: "HotTub/Sensor/TempWater"
    - name: "HotTub Cabinet Temp Sensor"
      state_topic: "HotTub/Sensor/TempOutside"
    - name: "HotTub PCB Temp Sensor"
      state_topic: "HotTub/Sensor/TempBoard"
    - name: "Energy Monitor AB"
      state_topic: "EngergyMonitor/PowerTotalABkwh"
      unit_of_measurement: "kWh"
      device_class: "energy"
      unique_id: energy_monitor_ab
      state_class: total
    - name: "Energy Monitor Max Current A"
      state_topic: "EngergyMonitor/IrmsAdjAMax"
      unit_of_measurement: "A"
      device_class: "current"
    - name: "Energy Monitor Max Current B"
      state_topic: "EngergyMonitor/IrmsAdjBMax"
    - name: "Water Meter"
      state_topic: "watermeter/sensor/total"
      unit_of_measurement: "L"
      device_class: "water"
      unique_id: water_meter
      state_class: total
############################### ALERTS #########################
#name after alert must be lower case
alert:
  simple_garage_after_dark:
    name: Garage Door Status
    message: Garage door opened
    done_message: Garage door closed
    entity_id: binary_sensor.garage_door_sensor
    state: "on"
    repeat: 1 # This will repeat every 5 minutes
    can_acknowledge: false
    skip_first: False
    notifiers:
      - mobile_app_RK_12_2
      - gmail #This is the "name" of the notification
  garage_temp_sensor:
    name: Garage Low Temperature
    entity_id: binary_sensor.garage_temp_low
    state: "on"
    repeat: 5
    skip_first: False
    message: The garage temperature is low
    done_message: The garage temperature has returned to normal
    notifiers:
     - gmail
  sump_level_sensor:
    name: Sump High Level
    entity_id: binary_sensor.sump_level_high
    state: "on"
    repeat: 1
    skip_first: False
    message: The sump level is high
    done_message: The sump level has dropped
    notifiers:
     - gmail
  hottub_water_temp_sensor:
    name: Hot Tub Low Temperature
    entity_id: binary_sensor.hot_tub_temp_low
    state: "on"
    repeat: 1
    skip_first: False
    message: Hot Tub Temperature is Low
    done_message: Hot Tub Temperature has Returned to Normal
    notifiers:
     - gmail
##################### Notification Setup for GMAIL/TEXT ##################
notify:
  - name: gmail
    platform: smtp
    server: smtp.gmail.com
    port: 587
    timeout: 15
    sender: sender
    encryption: starttls
    username: email
    password: pass
    recipient:
      - email
      - phone#@msg.telus.com
    sender_name: Home Assistant
########################### TEMPLATES #########################################
template:
  - binary_sensor:
      - name: "Garage Temp Low"
        state: "{{ states('sensor.garage_temp_sensor') | float(0) <= 10.0 and is_state('input_boolean.pause_alerts', 'off') }}"
  - binary_sensor:
      - name: "Sump Level High"
        state: "{{ states('sensor.sump_level_sensor') | float(0) >= 75.1 }}"
  - binary_sensor:
      - name: "Hot Tub Temp Low"
        #state: "{{ states('sensor.hottub_water_temp_sensor') | float(0) <= 30.0 }}"
        state: "{{ states('sensor.hottub_water_temp_sensor') | float(0) <= states('input_number.hot_tub_low_temp_alarm_setpoint') | float(0) }}"
###################### INPUT BOOLEANS ##############################################
input_boolean:
  pause_alerts:
    icon: mdi:toggle-switch
########################### Sensors ###################
  - platform: systemmonitor
    resources:
    - type: processor_use
    - type: disk_use_percent
      arg: "/"
    - type: disk_free
      arg: "/"
    - type: memory_use_percent
    - type: network_in
      arg: eth0
    - type: throughput_network_in
      arg: eth0
    - type: network_out
      arg: eth0
    - type: throughput_network_out
      arg: eth0
    - type: processor_temperature
    - type: last_boot
# OPTIONAL CPU Raspberry Pi Temp
  - platform: command_line
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    value_template: '{{ value | multiply(0.001) | round(2)  }}'
###### Utility Meter #######
utility_meter:
  daily_energy:
    source: sensor.energy_monitor_ab
    cycle: daily
    periodically_resetting: True
  monthly_energy:
    cycle: monthly
  daily_water:
    source: sensor.water_meter
    cycle: daily
this part:
you need to change it from sensor: to command_line:
Sorry to sound silly but like this ?
command_line:
    resources:
      arg: "/"
    - type: disk_free
      arg: "/"
    - type: network_in
      arg: eth0
      arg: eth0
    - type: network_out
      arg: eth0
      arg: eth0
    - type: last_boot
no.
only the command_line portion needs changed.
I think this should do it:
    resources:
      arg: "/"
    - type: disk_free
      arg: "/"
    - type: network_in
      arg: eth0
      arg: eth0
    - type: network_out
      arg: eth0
      arg: eth0
    - type: last_boot
command_line:
  - sensor:
Thank you!
