I have got this 3V light which has a red and black wires. I checked by connecting the red one to a 3V pin on my Raspberry Pi 4 and the black one to a ground pin and the light switches on nicely. Now, I would like to control it using Home Assistant.
From what I found connecting and controlling a fan on GPIO, we need to put a resistor and transistor: https://www.instructables.com/id/Control-a-Cooling-Fan-on-a-Raspberry-Pi-3/
What do I need for my light? Is it the same circuit to build? I am sorry as I am learning slowly electronic.
Thanks! I just bought a multimeter, I will receive it in a couple of days. A label on the light says 3V. That is the only info I have for the time being.
Hi Matthew,
I tried and it says 0.00 mV… It is weird because I tried again to connect it to a 3.3V pin on my Rasperry Pi 4 and it switches on.
Maybe I am not using my multimeter properly. But I used it the exact same way to measure voltage on a small AAA battery and I found 1.5V which is correct.
