Hello All,
I am a new Home Assistant User. I have a few cameras around my house and I would love to set them up in HA and add some features to them once I get them streaming and working. I currently have them working with ISpy and I have the IP and RTSP stream. I am able to view them on VLC and ISpy.
These are boavision ip cameras I also contacted them thinking I may be using the wrong address for home assistant but I tried all that they gave me so maybe its my config. I’m not to sure…
When I view the stream on VLC the username/password box pops up and I have to enter it for the stream to start. I was thinking maybe that’s my issue that HA is not using my user/pass in the config. Well anyways…
My rtsp addresses I can use according to boa is:
rtsp://10.0.0.24:554/11 or rtsp://10.0.0.24:554/12
In VLC I got it working with:
rtsp://10.0.0.24:554/1/h264major
Here is my config in HA.
Ive tried authentication basic and digest.
@zoogara I just got a stream working!
I changed generic to mjpeg and found a code sdk i used to see how it generated the url and I got it to stream. in the dashboard it updates every 10 seconds
I also tried to add 2 cams but only 1 is recognized.
do you know how to update cam on dashboard more frequently? also config for multiple cams here is what I have im gunna keep plating with it to get it.
In your Lovelace.yaml (or in the config dialog if you used the GUI) there is a camera_view: option - your only two choices are “auto” (what you have now) or “live”.
So it’s only every 10 secs or real time as far as I can see.
There is a custom card:
Which is also available though HACS. That lets you set LOTS of options.
So i finally got my streams working on home assistant. What do you do for recording? I would like to record on motion. I’m thinking about trying to setup frigate so i can detect people and cars. but the recording part I am just looking into now. this is all I have for my yaml atm. (my previous post with names on each cam.)
