hello I am a beginner I try to connect to the command line, but I always come across a command system where the commands are HA “our command line: $ ha help” thank you in advance for enlightening me.
Type login
to access the Linux command line. Maybe you might want to try some Google read-up about “HassOS command line”?
I’m trying to run the following commands to put home assistant on a hard drive
sudo fdisk -l
sudo cfdisk /dev/sda,
