I buyed a Moes Zigbee-Gateway (Modell: MHUB-W-Q).
I found no way to flash it with Tasmota.
This Gateway set a own Coordinator, the gateway not join my Zigebee-Network.
My Coordinator is an CC2531-Stick on Zigbee2Mqtt.
Any Solution to have two Coordinators in Network, or to modify the Moes-Gateway that
is be an router?
The WLAN-Module is an WRG1 (Chip-RTL8711AM), the Zigbee-Module an CS3L (Chip-EFR32MG21A020F768IM32-B)
The cc2531 is outdated and has low processing power, and is specifically not recommended for zigbee2mqtt.
https://www.zigbee2mqtt.io/guide/adapters/#not-recommended
As far as I know, you can only have one coordinator on a zigbee network.
Some have hacked tuya zigbee router’s to work with Home assistant, but not sure if your model can be. Here’s a guide on one.
You might be better off just getting one of the cc2652 based adapters listed on the zigbee2mqtt recommended list. I use the electrolama zzh and it works very well.
This Gateway has WRG1 Wlan Module. Based RTL8711AM and no Serial-Port on Board
https://developer.tuya.com/en/docs/iot/wrg1-datasheet?id=K97rig6mscj8e
I try this Pinout to flash it with Tasmota, but it did not work
What made you think it was flashable with tasmota?
That is correct, you can never have more than one Zigbee Coordinator on a Zigbee network.
But you can have several usb adapters flashed with router-firmware in the same network
