Connected speaker choice, Denon Heos wake on lan?
Hi, going to get a speaker connected to home assistant, but wonder if the Denon Heos Home 250/350 can wake on lan? So it starts to play direct without the need to press “on”? Or is there any other ethernet connected speaker that supports this function?
The reason: want to make it as easy as possible to start streaming from the ha controller (or the phone app…)
It can not use wake on lan, but it is also not needed, because it will never really sleep.
Btw. there is no on button
If you are looking to save on power, then a wireless speaker is probably not the way to go.
A single Denon HEOS 250 will use around 2.5KWh per yeah just standing by.
A single Denon HEOS 150 will use around 3.5KWh per yeah standing by.
No idea why smaller one is using more power, but it is what they say in the manual.
