Connecting a double wall socket to zigbee2mqtt
Newbie and heavily relaying on your support.
Was trying to connect a zigbee tuya double wall socket (manufacturer Living Dewise?) to Home assistant via Zigbee2mqtt. Device was falsely identified as single plug (TS011F_plug_1).
Switching power on and off turns on and off both plugs simultaneously. Is there any work around so I get separate entities for the two plugs?
Thanks a lot
