I am sharing this post as I didn’t really find anywhere a proven solution that would allow to connect an existing KNX setup to Home Assistant, without access to the original ETS project. Hoping that it might be useful to other people.
The existing installation
I recently moved to an apartment built about 15 years ago with an existing KNX setup. The original installation was done so that it could be controlled by calling some phone number and pressing some keys on the phone keyboard.
But who has a landline nowadays…
Since I moved I have always wanted to connect it to my existing Home Assistant platform but I didn’t have access to the ETS software or to the ETS project that was setup originally.
The initial idea
After some initial research I realized that the “official” way would be to buy a KNX interface or router and connect it to my network via ethernet. Some of them can be powered via the ethernet port and don’t require addition power supply. The problem is that
- my router is far from my cabinet with the KNX devices and running an ethernet cable between the two would have been quite complex
- an IP interface or router is quite expensive (about 170€ for some entry level ones)
I also read in some threads that there might be a need to register the IP interface in the ETS software but wasn’t entirely sure if it would be the case.
The final solution
After more research, I realized that busware.de developed the TUL board based on ESP32 that can connect to an existing KNX setup and be connected to home assistant via WiFI. The TUL board can’t be powered by the KNX bus though and needs to be powered from its USB-c port.
I just bought one, connected it, and it just worked! After flashing the TUL and setting up KNX in Home Assistant following the official integration I was able to listen to the KNX traffic from Home assistant.
I originally powered the TUL from a power bank as I didn’t have access to a power plug next to my KNX connections, but I then moved to powering it directly plugging it to 12V DC transfomer in my KNX cabinet.
In the end what I needed to buy was:
- a TUL device from busware
- some KNX bus cable to connect the TUL to the KNX bus using the black/red wires (I originally tried to use standard stranded wires but those don’t really work when connecting to KNX bus connectors) – I just needed 20 cm but couldn’t find any place where I could buy less than 5m
- a 12V DC red/black to 5.5V DC USB-c transformer (like the ones used in cars) to power the TUL from my cabinet
With all that, I was able to listen to events on the KNX bus and retro-engineer the devices I need to setup
The Home Assistant setup
On the Home Assistant side, after having connected the TUL by providing its IP I checked the “KNX” > “Group Monitor” tab to listen to the messages being sent when I was pressing buttons on switches/controllers in the apartment.
I realized that my lights and electrical blinds don’t seem to be connected to KNX but that all my climate control devices are.
I was then able to map the AC controllers and KNX addresses to the sensors in my home. Here is an example for the AC controller in my living room.
knx:
- name: "Temp Living"
state_address: "1/1/6"
type: temperature
sync_state: 3
number:
- name: "Temperature threshold Living"
address: "1/1/7"
state_address: "1/1/7"
type: temperature
min: 18
max: 23
step: 0.5
mode: slider
And with this, I am now able to see the temperature in the different rooms and set the threshold for those. This then triggers cooling/heating automatically.
Also, in my case, if I update the temperature threshold from the physical controllers, it gets updated automatically in Home Assistant, but your mileage might very much vary based on the existing KNX configuration.
With this setup I can now automate changing the threshold based on some rules or from my phone when I am not at home.
Conclusion
It is possible to connect an exisiting KNX setup to Home Assistant without access to the ETS project using a TUL from busware and connecting it to both the KXN bus and an existing WiFi.
This won’t give you the full power of KNX automations, but it can allow people to interact with existing KNX devices and sensors from Home Assistant.
