On this picture you see there are 6 RJ45 ports on my inverter.
I already cut a UTP cable, and connected pins 3 and 4 (and after as well 5 and 6) to A and B of an USR - DR164 serial rs485 to wifi converter and plugged the other side in the COM port and the RS485 port.
All combinations I tried didn’t gave any result.
The logs of home assistant say below error.
Logger: custom_components.growatt_modbus.growatt_modbus
Source: custom_components/growatt_modbus/growatt_modbus.py:489
Integration: Growatt Modbus (documentation, issues)
First occurred: 16:55:04 (436 occurrences)
Last logged: 19:39:25
[SharedConn 192.168.129.124:502] Resetting connection: transport error during block read
[SharedConn 192.168.129.124:502] Resetting connection: poll returned no data
[SharedConn 192.168.129.124:502] Resetting connection: retry poll returned no data
I have the feeling I already tried everything, with assistance of AI as well but can’t make any progress. So I hope someone of you has some suggestions that I can try to get it working.
Hmm, before i re-flashed the ShineX-usb module I briefly used the sys-com port; (if i remember correctly pins 3&4) with an elfi-ew11 modbus2tcp module, i used dupont cables to connect it (as the plug was too expensive with only using 2 wires )
Good to hear it works (in one go ) The only additional advise I can give you is to check put the solax intgration (especially when you want to control power (looking at your name you’re dutch ? ivm ‘salderen’ )
PS I don’t mind you marking the topic as solved (mark the proper reply as solution )
