Connecting Hass.io to ThinKNX
hi everyone and thanks in advance for your time, I am stuck with connecting hassio (installed on a rasp b 3) to my knx system which already works with a server box interface made by a firm called ThinKNX;
right now i can control my knx system through the App ThinKNX but i wish i could do that with Alexa.
when i use tunneling or the autodetect mode it says “can’t connect to knx interface” but when i use Routing It seems to work, and so I’ve tryed to write initially the address of my room lights, but when I turn them on from hass.io dashboard nothing happens. here I share the link to the interface that is installed in my house and with which I can control all my knx devices.
http://www.thinknx.com/v3/en/compact.html
On their website I can’t see that this device is a certified KNXnet/ip interface or router.
Can you connect from ETS over this device?
yeah it was programmed through ETS
