I need some support with connecting a Shelly 1 Mini G3 to my Home Assistant setup.
I have already multiple other Shelly Systems connected, e.g. Plug S. For the Plug S I didnt change any specific on the Webinterface, even not activating any MQTT or RPC or Webhook. They automatically appeared on HomeAssistant.
The new Mini G3 is not showing up on HomeAssistant.
Is there a different approach needed or do I have an issue with my Shelly Setup in HomeAssistant?
After doing some more research I have found a solution jere in the forum: I renamed the custom integration and all its configuration part and I can use now the old one (with the existing Shelly Systems) and the new one with the new Shelly 1 in parallel.
This allows me also to do a migration from the old to the new system without interrupting anything.
