After updating to 1.20.0 the sensors on my Olimex board became unavailable. This has happened in the past after a restart while using the api (was using MQTT instead because of this) so I went to remove the integration and re-add it but it was no longer there. So I tried to add it and it said something about missing the api so I added it back in and removed mqtt from the config but it still wouldn’t add it. I tried to reinstall via ESPHome OTA but it wouldn’t connect even though my router showed it on the network. So I tried to reflash the board via USB and was able to get it connected to my WIFI and added the integration. When I tried to reconnect via POE the log says Errno 111. So it seems to work fine on WIFI but not via POE. Here is my config:
esphome:
platform: ESP32
board: esp32-poe
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
#wifi:
# ssid: "Wxxxxxt IOT"
# password: "xxxxxxxxx"
# ap:
# ssid: "MB Closet Multi Sensor"
# password: "SxxxxxV"
#captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
#mqtt:
# broker: 192.168.1.120
# username: mqtt_broker
# password: Ba9xxxxfrdt
ota:
binary_sensor:
- platform: gpio
pin: GPIO14
name: "Master Bedroom Closet Motion Sensor"
device_class: motion
filters:
- delayed_off: 15000ms
- delayed_on: 0ms
- platform: dht
pin: GPIO15
model: dht22
temperature:
name: "Master Bedroom Closet Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
unit_of_measurement: "°F"
humidity:
name: "Master Bedroom Closet Humidity"
update_interval: 60s
Any ideas what might be going on?
