My hassio wont load since I’ve updated it from versino 0.56.2. All I get is loading data and then connection lost, reconnecting. home-assistant.log shows no errors. supervisor logs:
Have no idea where to go from here, thanks for any help!
$ hassio homeassistant update
$ hassio homeassistant checkHost:
$ hassio host hardware
17-11-04 18:25:16 INFO (MainThread) [main] Initialize Hassio setup
17-11-04 18:25:19 INFO (SyncWorker_0) [hassio.dock.interface] Attach to image vkorn/armhf-ps4waker with version None
17-11-04 18:25:19 INFO (SyncWorker_8) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-configurator with version 0.2.0-p3
17-11-04 18:25:19 INFO (SyncWorker_15) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-ssh with version 2.9
17-11-04 18:25:16 INFO (MainThread) [main] Setup HassIO
17-11-04 18:25:17 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.73
17-11-04 18:25:18 WARNING (MainThread) [hassio.addons.data] Can’t read /data/addons/git/53caca22/base_debian/config.json → required key not provided @ data[‘boot’]. Got None
17-11-04 18:25:19 INFO (SyncWorker_5) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-duckdns with version 1.0
17-11-04 18:25:19 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
exporting=False; node_id=4, value_index=32, value_instance=1, value_id=72057594110050816, old_entity_id=sensor.pralni_stroj_exporting_4_32, new_entity_id=sensor.pralni_stroj_exporting, power_consumption=0.0, unit_of_measurement=, friendly_name=Pralni Stroj E
nsumption=0.0, unit_of_measurement=V, friendly_name=Pralni Stroj Previous Reading @ 2017-11-04T19:29:27.031057+01:00>>
0>, new_state=<state sensor.pralni_stroj_previous_reading_3=237.94; node_id=4, value_index=17, value_instance=1, value_id=72057594110050578, old_entity_id=sensor.pralni_stroj_previous_reading_4_17, new_entity_id=sensor.pralni_stroj_previous_reading, power_co
ame=Pralni Stroj @ 2017-11-04T19:29:24.900814+01:00>, new_state=<state zwave.pralni_stroj=CacheLoad; node_id=4, node_name=Pralni Stroj, manufacturer_name=Neo CoolCam, product_name=Power plug 12A, old_entity_id=zwave.pralni_stroj_4, new_entity_id=zwave.pralni
2017-11-04 19:29:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pralni_stroj_exporting, old_state=<state sensor.pralni_stroj_exporting=False; node_id=4, value_index=32, value_instance=1, value_id=720575941100
7-11-04T19:29:27.859346+01:00>>
stroj, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=False, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={‘listening’, ‘beaming’, ‘routing’}, sentCnt=4, sentFailed=2, retries=0, receivedCnt=5, receivedDups=1
.pralni_stroj, query_stage=CacheLoad, is_awake=True, is_ready=False, is_failed=True, is_info_received=True, max_baud_rate=40000, is_zwave_plus=True, capabilities={‘listening’, ‘beaming’, ‘routing’}, sentCnt=6, sentFailed=4, retries=0, receivedCnt=5, received
2017-11-04 19:29:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.garage, old_state=<state cover.garage=closed; wifi_signal=-54, distance_sensor=297, door_state=closed, friendly_name=Garažna vrata, supported_fea
19:30; friendly_name=Ura: , icon=mdi:clock @ 2017-11-04T19:30:01.283741+01:00>>
2017-11-04 19:30:08 INFO (SyncWorker_1) [homeassistant.components.sensor.command_line] Running command: du -m /core-mariadb/home-assistant.db | cut -f1
du: /core-mariadb/home-assistant.db: No such file or directory
9:29:41.318846+01:00>, new_state=<state sensor.ram_available=612.9; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T19:30:12.340484+01:00>>
tures=3, device_class=garage, icon=mdi:garage @ 2017-11-04T19:27:06.134609+01:00>, new_state=<state cover.garage=closed; wifi_signal=-54, distance_sensor=235, door_state=closed, friendly_name=Garažna vrata, supported_features=3, device_class=garage, icon=mdi
2017-11-04 19:31:29 INFO (MainThread) [homeassistant.components.http] Serving /states to 192.168.1.1 (auth: False)
2017-11-04 19:31:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.cpu_used, old_state=<state sensor.cpu_used=3; unit_of_measurement=%, friendly_name=CPU used, icon=mdi:chip @ 2017-11-04T19:31:14.341966+01:00>,
2017-11-04 19:32:10 INFO (SyncWorker_17) [homeassistant.components.sensor.command_line] Running command: du -m /core-mariadb/home-assistant.db | cut -f1
new_state=<state sensor.cpu_used=16; unit_of_measurement=%, friendly_name=CPU used, icon=mdi:chip @ 2017-11-04T19:32:16.323190+01:00>>
2017-11-04 19:32:16 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.ram_available, old_state=<state sensor.ram_available=581.8; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T1
9:31:45.377701+01:00>, new_state=<state sensor.ram_available=610.2; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T19:32:16.349363+01:00>>
2017-11-04 19:32:18 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.garage, old_state=<state cover.garage=closed; wifi_signal=-54, distance_sensor=298, door_state=closed, friendly_name=Garažna vrata, supported_fea
2017-11-04 19:32:47 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.since_last_boot, old_state=<state sensor.since_last_boot=0:07:43.286611; unit_of_measurement=, friendly_name=Since last boot, icon=mdi:clock @ 2
new_state=<state sensor.cpu_used=3; unit_of_measurement=%, friendly_name=CPU used, icon=mdi:chip @ 2017-11-04T19:32:47.311635+01:00>>
tures=3, device_class=garage, icon=mdi:garage @ 2017-11-04T19:27:06.134609+01:00>, new_state=<state cover.garage=closed; wifi_signal=-54, distance_sensor=298, door_state=closed, friendly_name=Garažna vrata, supported_features=3, device_class=garage, icon=mdi
2017-11-04 19:33:16 INFO (MainThread) [homeassistant.components.discovery] Unknown service discovered: DLNA {‘host’: ‘192.168.1.50’, ‘port’: 50001, ‘ssdp_description’: ‘http://192.168.1.50:50001/desc/device.xml’, ‘name’: ‘Synology2’, ‘model_name’: ‘DS1812+’,
9:32:47.335340+01:00>, new_state=<state sensor.ram_available=611.8; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T19:33:18.290358+01:00>>
2017-11-04 19:33:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=cover.garage, old_state=<state cover.garage=closed; wifi_signal=-54, distance_sensor=298, door_state=closed, friendly_name=Garažna vrata, supported_fea
9:33:18.290358+01:00>, new_state=<state sensor.ram_available=612.0; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T19:33:49.341141+01:00>>
lni_stroj_energy=5.03; node_id=4, value_index=0, value_instance=1, value_id=72057594110050306, old_entity_id=sensor.pralni_stroj_energy_4_0, new_entity_id=sensor.pralni_stroj_energy, power_consumption=0.0, unit_of_measurement=kWh, friendly_name=Pralni Stroj
2017-11-04 19:39:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pralni_stroj_previous_reading_2, old_state=<state sensor.pralni_stroj_previous_reading_2=0.0; node_id=4, value_index=9, value_instance=1, value
id=72057594110050450, old_entity_id=sensor.pralni_stroj_previous_reading_4_9, new_entity_id=sensor.pralni_stroj_previous_reading, power_consumption=0.0, unit_of_measurement=W, friendly_name=Pralni Stroj Previous Reading @ 2017-11-04T19:36:35.930204+01:00>, n
_id=72057594110050642, old_entity_id=sensor.pralni_stroj_previous_reading_4_21, new_entity_id=sensor.pralni_stroj_previous_reading, power_consumption=0.0, unit_of_measurement=A, friendly_name=Pralni Stroj Previous Reading @ 2017-11-04T19:36:36.339012+01:00>,
2017-11-04 19:39:31 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.pralni_stroj_power_management, old_state=, new_state=<state sensor.ram_available=604.6; unit_of_measurement=MiB, friendly_name=RAM available, icon=mdi:memory @ 2017-11-04T19:39:54.986215+01:00>>
2017-11-04 19:39:55 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.cpu_used, old_state=<state sensor.cpu_used=3; unit_of_measurement=%, friendly_name=CPU used, icon=mdi:chip @ 2017-11-04T19:38:22.851629+01:00>,
tures=3, device_class=garage, icon=mdi:garage @ 2017-11-04T19:35:53.775864+01:00>, new_state=<state cover.garage=closed; wifi_signal=-53, distance_sensor=299, door_state=closed, friendly_name=Garažna vrata, supported_features=3, device_class=garage, icon=mdi
19:40; friendly_name=Ura: , icon=mdi:clock @ 2017-11-04T19:40:00.958003+01:00>>
17-11-04 18:25:17 INFO (MainThread) [hassio.host_control] Send ‘info’ to HostControl.
17-11-04 18:25:17 INFO (MainThread) [hassio.host_control] Receive from HostControl: { “type”: “resinos”, “version”: “1.1”, “last_version”: “1.1”, “hostname”: “hassio”, “features”: [“shutdown”, “reboot”, “update”, “hostname”], “os”: “GNU/Linux” }.
17-11-04 18:25:18 INFO (SyncWorker_0) [hassio.dock.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.57
required key not provided @ data[‘startup’]. Got None
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/27e642c6 repository
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/8f881235 repository
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/e5829d31 repository
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/53caca22 repository
17-11-04 18:25:18 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository
17-11-04 18:25:19 WARNING (MainThread) [hassio.addons.data] Can’t read /data/addons/git/53caca22/base_debian/config.json → required key not provided @ data[‘boot’]. Got None
17-11-04 18:25:19 INFO (MainThread) [hassio.addons] Load addons: 47 all - 47 new - 0 remove
17-11-04 18:25:19 INFO (SyncWorker_11) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-mariadb with version 0.1
17-11-04 18:25:19 INFO (SyncWorker_12) [hassio.dock.interface] Attach to image hassioaddons/terminal-armhf with version 2.0.1
17-11-04 18:25:19 INFO (SyncWorker_13) [hassio.dock.interface] Attach to image hassioaddons/homebridge-armhf with version 2.1.0
17-11-04 18:25:19 WARNING (SyncWorker_0) [hassio.dock.interface] Can’t read version from addon_e5829d31_ps4waker
17-11-04 18:25:19 INFO (SyncWorker_13) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-samba with version 2.0
17-11-04 18:25:19 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
17-11-04 18:25:19 INFO (MainThread) [main] Run HassIO
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/notoriousbdg/hassio-addons repository
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - vkorn/hassio-addons: Hass.io add-ons repository
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - bestlibre/hassio-addons repository
17-11-04 18:25:19 INFO (MainThread) [hassio.addons.git] Pull addon GitHub - balloob/hassio-addon-experiments: Collection of add-on experiments for Hass.io repository
17-11-04 18:25:19 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-11-04 18:25:19 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-11-04 18:25:20 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-11-04 18:25:20 INFO (MainThread) [hassio.addons] Startup system run 1 addons
17-11-04 18:25:20 INFO (SyncWorker_1) [hassio.dock.interface] Clean homeassistant/armhf-addon-mariadb docker application
17-11-04 18:25:21 WARNING (MainThread) [hassio.addons.data] Can’t read /data/addons/git/53caca22/base_debian/config.json → required key not provided @ data[‘boot’]. Got None
17-11-04 18:25:21 INFO (MainThread) [hassio.addons] Load addons: 47 all - 0 new - 0 remove
17-11-04 18:25:23 INFO (SyncWorker_1) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-mariadb with version 0.1
17-11-04 18:25:23 INFO (MainThread) [hassio.addons] Startup services run 4 addons
17-11-04 18:25:23 INFO (SyncWorker_11) [hassio.dock.interface] Clean homeassistant/armhf-addon-duckdns docker application
17-11-04 18:25:23 INFO (SyncWorker_16) [hassio.dock.interface] Clean homeassistant/armhf-addon-ssh docker application
17-11-04 18:25:23 INFO (SyncWorker_2) [hassio.dock.interface] Clean homeassistant/armhf-addon-samba docker application
17-11-04 18:25:23 INFO (SyncWorker_12) [hassio.dock.interface] Clean hassioaddons/terminal-armhf docker application
17-11-04 18:25:29 INFO (SyncWorker_11) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-duckdns with version 1.0
17-11-04 18:25:29 INFO (SyncWorker_2) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-samba with version 2.0
17-11-04 18:25:30 INFO (SyncWorker_16) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-ssh with version 2.9
17-11-04 18:25:31 INFO (SyncWorker_12) [hassio.dock.addon] Start docker addon hassioaddons/terminal-armhf with version 2.0.1
17-11-04 18:25:31 INFO (SyncWorker_17) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-11-04 18:25:35 INFO (SyncWorker_17) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.57
17-11-04 18:25:35 INFO (MainThread) [hassio.addons] Startup application run 3 addons
17-11-04 18:25:35 INFO (SyncWorker_15) [hassio.dock.interface] Clean vkorn/armhf-ps4waker docker application
17-11-04 18:25:35 INFO (SyncWorker_0) [hassio.dock.interface] Clean hassioaddons/homebridge-armhf docker application
17-11-04 18:25:35 INFO (SyncWorker_8) [hassio.dock.interface] Clean homeassistant/armhf-addon-configurator docker application
17-11-04 18:25:44 INFO (SyncWorker_15) [hassio.dock.addon] Start docker addon vkorn/armhf-ps4waker with version None
17-11-04 18:25:44 INFO (SyncWorker_0) [hassio.dock.addon] Start docker addon hassioaddons/homebridge-armhf with version 2.1.0
17-11-04 18:25:45 INFO (SyncWorker_8) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-configurator with version 0.2.0-p3
17-11-04 18:31:16 INFO (SyncWorker_9) [hassio.dock] Run command ‘python3 -m homeassistant -c /config --script check_config’ on homeassistant/raspberrypi3-homeassistant
17-11-04 18:34:44 INFO (SyncWorker_16) [hassio.dock.interface] Restart homeassistant/raspberrypi3-homeassistant
