Connection lost. Reconnecting…
Hello, I’m currently working on HAOS installed on VMware, everything was working fine unless these 2 days I’m facing a problem of Connection lost. Reconnecting… after 10sec maximum of booting the OS,any suggestion on how to fix this problem, it’s really urgent!!!
Hey, I solved this by doing a hard restart of my PC. It turns out I was running out of memory, but I didn’t have any clear error messages indicating this. I tried running the backup on another setup and it worked perfectly, which confirmed it was just a memory issue. Thanks to the community for the support!
I have same issue. MacOS Taboe en safari show me all the time connection lost. Reconnecting.
When reload the page it’s gone. But before that I can’t even browse the HA portal.
It started when updated to MacOS Taboe…
Known issue in MacOS (something screewed in Safari, not HA). Workaround is to use nDNS instead of IP (e.g. homeassistant.local:8123). Or if you have external access configured with own domain, that use this. In most cases work properly.
