I’m using the Ruckus Unleashed integration. But since smartphones tend to sleep every now and then I get devices flapping from/to away and home.
I figured if I could just set the consider_home to a higher value that would solve it. But I don’t see any configuration option for that.
I installed the Ruckus Unleashed via the gui of home assistant. If I would have configured it via yaml then I think I could just add a key consider_home to the configuration.
Can I set the consider_home flag globally for all device trackers ?
Unfortunately this doesn’t solve the flapping issue.Thanks anyway…!
I think I read somewhere that the consider_home variable is a global setting for all device trackers. I tried to set a kind of fake nmap scanner device tracker with the setting hoping that this would help for the Ruckus Unleashed integration, but too bad for me … Doesn’t work…
