Folks, I really need some advice here. I was running my install from a pi but I kept getting these weird errors form my lights (shown in pic). Sometimes a wipe restore would work sometimes not. I moved to VMware and that solved the issue for a while, them it crept up again. I’m at my wits end.
/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py:981: InsecureRequestWarning: Unverified HTTPS request is being made to host ‘192.168.254.241’. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#ssl-warnings
warnings.warn(
2020-10-17 19:06:58 ERROR (MainThread) [homeassistant.components.synology.camera] Error when initializing SurveillanceStation
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 426, in _make_request
six.raise_from(e, None)
File “”, line 3, in raise_from
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 421, in _make_request
httplib_response = conn.getresponse()
File “/usr/local/lib/python3.8/http/client.py”, line 1347, in getresponse
response.begin()
File “/usr/local/lib/python3.8/http/client.py”, line 307, in begin
version, status, reason = self._read_status()
File “/usr/local/lib/python3.8/http/client.py”, line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), “iso-8859-1”)
File “/usr/local/lib/python3.8/socket.py”, line 669, in readinto
return self._sock.recv_into(b)
File “/usr/local/lib/python3.8/ssl.py”, line 1241, in recv_into
return self.read(nbytes, buffer)
File “/usr/local/lib/python3.8/ssl.py”, line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File “/usr/local/lib/python3.8/site-packages/requests/adapters.py”, line 439, in send
resp = conn.urlopen(
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 726, in urlopen
retries = retries.increment(
File “/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py”, line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File “/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py”, line 735, in reraise
raise value
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 670, in urlopen
httplib_response = self._make_request(
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 428, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File “/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py”, line 335, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host=‘192.168.254.241’, port=5001): Read timed out. (read timeout=5)
File “/usr/src/homeassistant/homeassistant/components/synology/camera.py”, line 56, in async_setup_platform
surveillance = await hass.async_add_executor_job(
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/usr/local/lib/python3.8/site-packages/synology/surveillance_station.py”, line 12, in init
self._api = Api(url, username, password, timeout, verify_ssl)
File “/usr/local/lib/python3.8/site-packages/synology/api.py”, line 59, in init
self._initialize_api_info()
File “/usr/local/lib/python3.8/site-packages/synology/api.py”, line 69, in _initialize_api_info
response = self._get_json_with_retry(self._base_url + ‘query.cgi’,
File “/usr/local/lib/python3.8/site-packages/synology/api.py”, line 192, in _get_json_with_retry
return self._get_json(url, payload)
File “/usr/local/lib/python3.8/site-packages/synology/api.py”, line 198, in _get_json
response = self._get(url, payload)
File “/usr/local/lib/python3.8/site-packages/synology/api.py”, line 184, in _get
response = requests.get(url, payload, timeout=self._timeout,
File “/usr/local/lib/python3.8/site-packages/requests/api.py”, line 76, in get
return request(‘get’, url, params=params, **kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/api.py”, line 61, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/sessions.py”, line 530, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/sessions.py”, line 643, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.8/site-packages/requests/adapters.py”, line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host=‘192.168.254.241’, port=5001): Read timed out. (read timeout=5)
