Hello, I’m still new to Home Assistant, but I’m getting increasingly frustrated. I keep losing included devices or entities.
For example, at noon today, I included a new Z-Wave switch. I was able to switch the device. This evening, I wanted to integrate it into a script. However, it was gone. It was also missing from the Z-Wave device overview. So, I excluded it again, and Home Assistant showed me a successful exclusion with a previously invisible node.
The re-inclusion then worked.
I then wanted to use it in the script, but in the meantime, other entities that had previously all worked had disappeared. In the visual editor, these entities were no longer listed with the device name but with the ID number. However, they were no longer responsive.
Are you familiar with this problem? What is happening here?
My HA runs on a Raspberry Pi 5 with a Aeotec Z-Stick 10 Pro - Zigbee 3.0 & Z-Wave 800 Series USB Adapter. Can this adapter be te problem
