Hello dear community,
I’m still fairly inexperienced with Home Assistant. So far, I’ve managed to get everything working, but I have an idea that I can’t seem to get right.
I use a Liquid Check fill level indicator for my cistern.
I was able to integrate this into my system without any problems and I get values in liters, height, and percentage.
Now I would like a meter for my rainwater consumption. This should be possible using the fill level. I’ve already configured a consumption meter, simply using the liter sensor entity. This also counts, but unfortunately, it simply adds the negative and positive values together. Is it possible to have the meter add only negative values, or conversely, only positive values?
