I’m running Home Assistant on an Intel NUC and all of a sudden (worked fine for 2 years) the UI is not loading (no connection). I’m stuck in a strange state where Home Assistant Core runs, but port 8123 is not exposed, so the UI is unreachable from my network.
Current Situation
- NUC boots normally.
homeassistantcontainer is running (docker psshows it as “Up”).- However, the PORTS column is empty** (no
0.0.0.0:8123->8123/tcp). - As a result, the UI is not accessible via
http://<NUC-IP>:8123. - Inside the container, HA appears to be running.
When I run:
docker exec homeassistant curl -v http://localhost:8123
I get a successful connection, so HA is listening internally.
But externally, the port is not published.
Anyone has a clue how to fix this?
