Just in case you missed it you must first refresh before the context is displayed. When you start nodered, you will see in the log a confirmation, that it loaded both memory and local file system. Are there any warnings? Then in the change node you should see the little hamburger menu?
If that is all there itâs probably fine but yeah this would drive me nuts.
Of course I know about the update button. I used the context data sidebar all the time before adding the filesystem storage and it worked fine all the time.
The only data objects I can see there are âactionflowsâ and âhomeassistantâ in the âGlobalâ section. Both marked as saved in the file system. But all Flow variables and my own global variables are missing.
There are two warnings an one error in the log which I will have to look after. But I donât think they are related to the problem:
Edit: Well, now after several restarts, injections and reloading of the flow variable view they are shown. I donât know why they stayed invisible before. The logs have not changed. This was strange behavior but now everything is displayed just fine.
Iâm on the latest version, have file storage as default and can see all values. Have either of you tried to reinstall, that seems to be your next step. Make sure to remove the node red folder completely.
Back up all flows, delete the addon, rename the nodered folder node-red.old reboot the host. go to settings, system, hardware, three dots on right, choose reboot host. Then reinstall.
