While it isn’t dramatic at the Moment, one could say as well that it increased by 100% within 6 Month
And i really don’t know what causes that. So i want to find the culprit - but how can i do this?
I catch the CPU Usage (both % and load 5min) via the platform: systemmonitor . But i would need something more specific.
How can i tell which Addons, processes, Component increase in Usage?
I remembered that as well, but i think there is no Sensors for that Purpose:
Glances integration will add the following sensors if available in the platform:
For each detected disk (or mount point) the following sensors will be created:
disk_use_percent: The used disk space in percent.
disk_use: The used disk space.
disk_free: The free disk space.
memory_use_percent: The used memory in percent.
memory_use: The used memory.
memory_free: The free memory.
swap_use_percent: The used swap space in percent.
swap_use: The used swap space.
swap_free: The free swap space.
processor_load: The load.
process_running: The number of running processes.
process_total: The total number of processes.
process_thread: The number of threads.
process_sleeping: The number of sleeping processes.
cpu_use_percent: The used CPU in percent.
sensor_temp: A temperature sensor for each device that provides temperature (depends on platform).
docker_active: The count of active Docker containers.
docker_cpu_use: The total CPU usage in percent of Docker containers.
docker_memory_use: The total memory used by Docker containers.
For each detected raid the following sensors will be created:
raid_available: The number of available devices for the raid.
raid_used: The number of devices used by the raid.
Or did i miss something terrible, which sensor(s) would you go for?
I think that a Live screen might not be helpful if i want to observe increasing usage over a couple of month Anyway, i am not sure wether i could access that Screen with HAOS as System, too.
But yes, having that listing as sensors to keep track of would be perfect
