Continual Your dashboard was updated prompts
Hi All,
It might not be related but since 2025.4.1 I keep on getting continual dashboard updated prompts on the default overview dashboard. It seems to pop up every 30 sec or so I also notice that it sometimes resets itself to the default order and unhides hidden areas until I hit the refresh button, then it goes back to how I have it configured. Anyone have any ideas on where I can look for this one or what could be triggering it?
btw. this is happening on both my iPhone (ha app) and Safari on Mac
Does it happen on PC when you are not touching other clients?
Yeah it does, I disconnected all other clients and booted a windows machine. It’s doing the same thing on edge.
Make sure you time is correct and not drifting.
Thanks Wally, it’s a container so gets time from unraid. I checked anyway and time is spot on.
Then you probably have a browser cache issue and you need to completely clear the browser cache for all HA related connections.
Hi Wally,
Yeah I thought that too, first thing I did on my Mac (my primary machine). Odd that’s its occurring on Windows, Mac and my iPhone HA app.
Then it must be the time either on your HA or on all your client devices.
Check your timezone too.
One of the latest HA core update comes with a function that checks if the browser is showing old content and if it then shows the message you see.
Signed up to say I’m having the same annoying issue. Surely if it is happening in the native iOS app it can’t be a browser issue?
There are others with the issue too. This seems like a bug introduced in 2025.4:
The native apps are also based on browsers, but they are skinned.
I do not know what the iOS embedded browser is called, since I do not use iOS devices, but on Android it is called Goggle WebView.
It is Safari
Okay.
I knew it was based on Safari, but not that the name was the same.
Google WebView is based on Chromium, like Google Chrome, so it is basically a skinned Google Chrome.
Is the change to HA maybe not working correctly in Safari? I’ve noticed @BlairC is using iOS app and Safari on Mac same as I am.
We would have seen thousand of posts on the forum by now then, if it was a general issue.
It might be related to iOS, but there should then be some other thing in combination with it tø keep the number of incidents down.
The fact that it shows another dashboard with a setup that is not your current suggest that it is a browser cache issue.
But it’s also not isolated to one person. At least three instances of the same issue and 2025.4 hasn’t been out that long and it looks like the change was only introduced in 2025.4.1 which has been out even less time and many don’t update to the point releases unless it fixes a specific issue.
There must be some combination of things going on here that’s causing it. It’s just a very annoying popup and I never had an issue prior to 2025.4.
I haven’t had any weird dash issues. Just this annoying popup. It can happen on any page I’m viewing within HA. Even an add-on interface.
The only other thing that changed on Sunday was daylight savings ended for us here in Aus. I wonder if it’s related.
That is a good bet.
If the daylight saving in the system for AUS does not match the real world, then you would get the issue you describe.
Have AUS changed daylight saving times recently?
Sometimes real world changes can take time to get implemented in computer systems, so if politicians have moved the daylight saving dates, then it might be it.
Nope, no daylight savings changes here and all of my devices updated correctly, has always been the first Sunday in April as far as I know.
I’m having the same issue all of a sudden as well.
also seeing this
