Home assistant on Pi 3B, Node Red, Mosquitto and Configurator installed. This is all a fresh installation today.
I’m trying to install TheHookUps holiday LED scripts/code, but I keep getting errors. The errors I get are these:
From the log file (after check config button pressed):
while parsing a block mapping
in "/config/configuration.yaml", line 18, column 3
expected <block end>, but found '<block mapping start>'
in "/config/configuration.yaml", line 52, column 5
From the notification icon within configurator:
bad indentation of a mapping entry at line 52, column 5:
For the life of me I cannot see what the issue is. I’ve tried indenting it further right and left. copied and pasted from another line that is closely similar (line 76) but I still get this. Could someone please explain to me what is going wrong?
Here is my configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
broker: 192.168.1.10
# Example configuration.yaml entry
mobile_app:
#start holiday leds
switch:
- platform: mqtt
state_topic: "holidayLights/audio/state"
command_topic: "holidayLights/addEffects"
payload_on: "Audio On"
payload_off: "Audio Off"
retain: false
- platform: mqtt
state_topic: "holidayLights/glitter/state"
payload_on: "Glitter On"
payload_off: "Glitter Off"
retain: false
- platform: mqtt
name: "Add Lightning"
state_topic: "holidayLights/lightning/state"
payload_on: "Lightning On"
payload_off: "Lightning Off"
retain: false
light:
#platform: mqtt_json
# the most recent HA requires a different platform
platform: mqtt
schema: json
state_topic: "holidayLights/state"
command_topic: "holidayLights/commands"
effect: true
brightness: true
effect_list:
- Color_Chase
- Color_Glitter
- Single_Race
- Double_Crash
- Rainbow
- Blocked_Colors
- BPM
- Twinkle
- Fire
- Fill_Solid
- Spooky_Eyes
- Halloween
- LED_Locator
qos: 1
- #platform: mqtt_json
platform: mqtt
schema: json
name: "Holiday Lights Color 1"
state_topic: "holidayLights/state1"
command_topic: "holidayLights/commands1"
rgb: true
qos: 1
platform: mqtt
schema: json
name: "Holiday Lights Color 2"
state_topic: "holidayLights/state2"
command_topic: "holidayLights/commands2"
rgb: true
qos: 1
platform: mqtt
schema: json
name: "Holiday Lights Color 3"
state_topic: "holidayLights/state3"
command_topic: "holidayLights/commands3"
rgb: true
qos: 1
input_number:
led_identification:
name: LED identification
initial: 0
min: 0
max: 500
step: 1
#end holiday leds
Thanks, Colin
