I use Youtube Music and was tired of my music not continuing on my speakers when I got home, so of course I automated it. Big thanks to KoljaWindeler for his ytube_music_player.
It’s pretty easy to setup up, but requires a few things.
- HACS Add-on: ytube_music_player
- Last Notification & Geo Location sensors in the Home Assistant Companion App
- Your AppDaemon configuration:
system_packages:
- py3-wheel
- git
python_packages:
- importlib_resources
- git+https://github.com/khmikkelsen/ytmusicapi.git
init_commands: []
- Example apps.yaml entry, replace values with your own:
music_transition:
module: music_flow
class: MusicFlow
last_notification_sensor: sensor.oneplus_6t_last_notification
device_tracker: device_tracker.kristians_oneplus
start_sensor: binary_sensor.hallway_door_sensor_contact
speakers: media_player.all_speakers
default_playlist_id: <your favorite playlist or mix id here>
Optional parameters:
only_alone
false if you want your music to play even though you are not alone at home.
When you get within your home zone, it will prepare the speakers to minimize delay between the ‘start’ sensor triggering and you listening to your music, after which it will play the song you are listening to on your speakers, from the second it was when the sensor triggered (within a 1-2 second error margin).
I havn’t found a way to get your current queue from the Youtube Music API, so atm I’m defaulting to my supermix after the first track is done. This is a required parameter because otherwise it will keep playing the same track.
At the moment, I’m using a fork of the unofficial ytmusicapi because it uses pkg_resources which throws errors in python3.9, but I will change this accordingly with developments.
View the source code here or below:
from re import search
import appdaemon.plugins.hass.hassapi as hass
import json
from ytmusicapi import YTMusic
YTM_APPINFO = 'com.google.android.apps.youtube.music'
YTM_PLAYER = 'media_player.ytube_music_player'
# noinspection PyAttributeOutsideInit
class MusicFlow(hass.Hass):
def initialize(self):
self.log("initializing ...")
try:
self.last_song = None
self.song_uri = None
if self.args.get('logger'):
self.logger = self.get_user_log(self.args['logger'])
self.notification_sensor = self.args['last_notification_sensor']
self.tracker = self.args['device_tracker']
self.trigger_play_sensor = self.args['start_sensor']
self.speakers = self.args['speakers']
self.default_playlist = self.args['default_playlist_id']
self.only_alone = self.args.get('only_alone')
self.only_alone = False if self.only_alone else True
self.ytm = YTMusic()
self.home_handle = self.listen_state(self.entered_home_zone_cb, self.tracker, new='home', old='not_home')
self.noti_handle = self.listen_state(self.new_notification_cb, self.notification_sensor, attribute='all', immediate=True)
self.content_id = None
self.play_handle = None
self.default_handle = None
self.log('MusicFlow initiated', log='main_log')
except (TypeError, ValueError) as e:
self.log('Incomplete configuration', level="ERROR")
raise e
def new_notification_cb(self, entity, attribute, old, new, kwargs):
attrs = self.get_state(entity, attribute=attribute).get('attributes')
if appinfo := attrs.get('android.appInfo'):
if search(YTM_APPINFO, appinfo):
self.last_song = (
attrs['android.title'],
attrs['android.text'],
attrs['post_time'])
self.content_id = self.get_content_id()
self.log(self.last_song, self.content_id)
def entered_home_zone_cb(self, entity, attribute, old, new, kwargs):
if (self.only_alone and self.is_alone()) or self.only_alone is False:
self.prepare_speakers()
self.play_handle = self.listen_state(
self.start_playing_cb,
entity=self.trigger_play_sensor,
new="on",
old='off',
oneshot=True)
def start_playing_cb(self, entity, attribute, old, new, kwargs):
self.call_service("media_player/play_media",
entity_id=YTM_PLAYER,
media_content_id=self.content_id,
media_content_type='track')
diff = round(self.get_now_ts() - self.last_song[2] / 1000)
self.call_service("media_player/media_seek",
seek_position=diff)
self.cancel_listen_state(self.play_handle)
self.default_handle = self.listen_state(
self.to_default_playlist_cb,
entity=self.speakers,
to='idle',
oneshot=True)
def to_default_playlist_cb(self, entity, attribute, old, new, kwargs):
media_content_id=self.default_playlist,
media_content_type='playlist')
self.cancel_listen_state(self.default_handle)
def prepare_speakers(self):
self.call_service("media_player/select_source",
source=self.speakers,
entity_id=YTM_PLAYER)
def is_alone(self, **kwargs):
alone = False
trackers = self.get_trackers()
for tracker in trackers:
if tracker != self.tracker:
state = self.get_state(tracker)
self.log(f'external trackers: {str(tracker)}, state: {state}')
alone = (state == 'home') or alone
return not alone
@property
def song_query(self):
return f'{self.last_song[0]} - {self.last_song[1]}'
def get_content_id(self):
ans = self.ytm.search(self.song_query, filter='songs', limit=1)
self.log(f'len: {len(ans)}, result: {str(ans[0]["title"])}')
return ans[0]['videoId']
