I am using YAML code from github to control my Deye Solar Inverter.
The code generates Control items and Sensors in Home Assistant under Settings > Devices > ESPHome > Deye 8K
I have sensor data 24 x 7 and I use the data in a dashboard and I look at History too.
The problem I have is with Control Items - to change values on the Deye. The list of Control Items disappears regularly, and then, out of the blue, returns.
The problem I have is that I have an automation which changes one value in the Deye. Of course, if it does not exist to change, then it cannot do it.
I have no idea as to how or why it disappears. Would it help to poll something once per hour to keep it ?
I found last night that the Control items are in the ESP32 when I browse to it, but the Control Items are missing from HA. So the problem is definitely with Control Items not finding their way AT TIMES from the ESP32 into HA
I am really struggling to get a log. I tried using Find Wirelessly and it can’t find it. I tried directly connected, but the USBTTY port is not shown as an option (I think because it is a docker container).
If I unplug it and connect it into my laptop, then of course I am resetting the device
Perhaps focusing on what appears to be a failure to communicate should be the first step. It might even “fix” the original issue, since lack of communication tends to make things not work.
HA (or ESPHome) renamed entites - added prefix with ESP name for half of them. I’ve renamed it back already 2 times during month. ChatGPT suggested to hardcode Object_Id in code on ESP, but I have no inspiration for now.
