Control Lutron Grafik Eye 3000 via IR with Broadlink RM4 Mini
Picked up a RM4 mini on Ali which turned out to be the 2019 version. Took a fair amount of time to find compatible IR codes for the lutron grafik eye so posting here to help anyone else coming to this. You can use the commands directly, eg, from a dashboard button, or incorporate into script.yaml.
These are the codes used to control via HA and rm4 mini
Lutron Preset 1: | b64:JgAUAAACoeBK4EpKAAErSkrg4EpKAAErDQUAAA==
Lutron Preset 2: | 64:JgAUAAACoeBK4EpKAAErSkqVSpVKAAHBDQUAAA==
Lutron Preset 3: | 64:JgAWAAACoeBK4EpKAAErSkqVSkpKSpUAASsNBQ==
Lutron Preset 4: | b64:JgAUAAACoeBK4EpKAAErSkpK4OBKAAErDQUAAA
Lutron OFF: | b64:JgAUAAACoeBK4EpKAAErSkrgSpVKAAF2DQUAAA==
This is in the script.yaml
script:
  lutron_off:
    alias: "Lutron Off"
    sequence:
      - service: remote.send_command
          entity_id: remote.lutron_scenes  # Your Broadlink entity ID
          command: b64:JgAUAAACoeBK4EpKAAErSkrgSpVKAAF2DQUAAA==
  lutron_preset1:
    alias: "Lutron Preset 1"
    sequence:
          command: b64:JgAUAAACoeBK4EpKAAErSkrg4EpKAAErDQUAAA==
  lutron_preset2:
    alias: "Lutron Preset 2"
    sequence:
          command: b64:JgAUAAACoeBK4EpKAAErSkqVSpVKAAHBDQUAAA==
  lutron_preset3:
    alias: "Lutron Preset 3"
    sequence:
          command: b64:JgAWAAACoeBK4EpKAAErSkqVSkpKSpUAASsNBQ==
  lutron_preset4:
    alias: "Lutron Preset 4"
    sequence:
          command: b64:JgAUAAACoeBK4EpKAAErSkpK4OBKAAErDQUAAA
and an example button
show_name: true
show_icon: true
type: button
name: Lutron Preset 4
icon: mdi:lightbulb-on-outline
tap_action:
  action: call-service
hold_action:
  action: none```
