Zigbee2 mqt-log
I have copied only the last part where you can se the signals from the controller.
Zigbee2mqtt
Zigbee2MQTT:info 2020-10-09 15:02:25: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"toggle","battery":60,"brightness":115,"linkquality":34,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:25: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":34,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:25: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'toggle'
Zigbee2MQTT:info 2020-10-09 15:02:25: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"toggle","battery":60,"brightness":115,"linkquality":36,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:25: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":36,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:28: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_step_up","action_step_size":1,"action_transition_time":0,"battery":60,"brightness":115,"linkquality":39,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:28: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":39,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:28: MQTT publish: topic 'homeassistant/device_automation/0x680ae2fffe1aa9d6/action_brightness_step_up/config', payload '{"automation_type":"trigger","device":{"identifiers":["zigbee2mqtt_0x680ae2fffe1aa9d6"],"manufacturer":"IKEA","model":"SYMFONISK sound controller (E1744)","name":"SYMFONISK sound controller - Badeværelset","sw_version":"Zigbee2MQTT 1.15.0"},"payload":"brightness_step_up","subtype":"brightness_step_up","topic":"zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action","type":"action"}'
Zigbee2MQTT:info 2020-10-09 15:02:28: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_step_up'
Zigbee2MQTT:info 2020-10-09 15:02:31: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_step_down","action_step_size":1,"action_transition_time":0,"battery":60,"brightness":115,"linkquality":42,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:31: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":42,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:31: MQTT publish: topic 'homeassistant/device_automation/0x680ae2fffe1aa9d6/action_brightness_step_down/config', payload '{"automation_type":"trigger","device":{"identifiers":["zigbee2mqtt_0x680ae2fffe1aa9d6"],"manufacturer":"IKEA","model":"SYMFONISK sound controller (E1744)","name":"SYMFONISK sound controller - Badeværelset","sw_version":"Zigbee2MQTT 1.15.0"},"payload":"brightness_step_down","subtype":"brightness_step_down","topic":"zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action","type":"action"}'
Zigbee2MQTT:info 2020-10-09 15:02:31: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_step_down'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_move_down","action_rate":195,"battery":60,"brightness":115,"linkquality":44,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":44,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_move_down'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_stop","battery":60,"brightness":115,"linkquality":42,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":42,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_stop'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_stop","battery":60,"brightness":115,"linkquality":44,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_stop","battery":60,"brightness":115,"linkquality":36,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:33: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":36,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_move_up","action_rate":195,"battery":60,"brightness":115,"linkquality":26,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":26,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_move_up'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"brightness_stop","battery":60,"brightness":115,"linkquality":21,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset', payload '{"action":"","battery":60,"brightness":115,"linkquality":21,"rate":195,"update":{"state":"idle"},"update_available":false}'
Zigbee2MQTT:info 2020-10-09 15:02:36: MQTT publish: topic 'zigbee2mqtt/SYMFONISK sound controller - Badeværelset/action', payload 'brightness_stop'
