ControllerX. Bring full functionality to light and media player controllers
Hi @gibman,
Indeed, this is possible. Not sure which type of “combination” you are referring, but you could make the controller to:
  • Click on: turn the light on
  • Click off: turn the light off
  • Double click on: full brightness
  • Double click off: min brightness
  • Hold on: change brightness where each time you hold it changes direction
  • Hold off: change color (in a loop)
This is the combination for this:
example_app:
  module: controllerx
  class: E1743Controller
  controller: XX:XX:XX:XX:XX:XX  # your controller IEEE id
  integration: zha
  light: light.your_light
  mapping:
    "on": "on"
    "off": "off"
    "on$2": on_full_brightness
    "off$2": on_min_brightness
    move_with_on_off_0_83: hold_brightness_toggle
    move_1_83: hold_color_up
    stop: release
You can see the key values of the mapping from the E1743 controller page and the values from the mapping in the custom mapping page.
If you let me know what is exactly you want to achieve, I can help you out with the configuration.
Cheers,
Xavi M.
Hi there,
I need some help :slight_smile:
I want to control an Ikea Synfonisk speaker using the Synfonisk remote. I am using ConbeeII/Deconz (no Ikea gateway) and this is my configuration so far:
synfonisk_speaker:
module: controllerx
class: E1744MediaPlayerController
controller: symfonisk_sound_controller
integration: deconz
media_player: media_player.kok
delay: 150
If I click once on it it does start playing (after 7 seconds delay), one more click and nothing happens, it is not pausing. Rotating the controller has erratic behaviour, only can increase volume one step and rotating anticlockwise sometimes increases the volume :frowning: any ideas what could be the reason?
I am trying also to use an Ikea Switch to control TV volume. The switch is already configured to switch on/of a light (In Phoscon), I would like to use hold-down to control TV volume from the same switch. Is that possible?
Thanks in advance!
Hi @Aie,
If you have a 7 seconds delay, I would say you have a problem in the network or the device is overloaded. Here are some things to check:
  • Which hardware is controlling the system? I currently have z2m, deconz, appdaemon, mqtt broker, and HA in a raspi4, but I know this same setup works well in raspi3. I would recommend you to check the CPU usage and free memory of your device.
  • Is the controller far from the coordinator (ConBee II)? If the controller is far away, then it might cause unexpected delays.
  • If you disconnect AppDaemon for a second, and check the deconz_event in the Developer Tools, do you see the delay in there too? Could you try to do the same with AppDaemon and ControllerX up and running?
  • Could you share the AppDaemon logs when using the controller with ControllerX?
You said you want this behaviour with an “Ikea Switch”, the same symfonisk controller or another one? If the Controller supports hold and release action (symfonisk doesn’t), then yes, it is possible to do so. If you share the already working configuration I can help you to modify it to do so.
Regards,
Xavi M.
Thank you Xavi for the quick replay.
For the first issue with the Symfonisk controller it is then most probably a hardware issue as I am testing with one of the early RPis I had over. I was actually surprised it worked so well with a few lamps, switches, Combee stick, a few automations. I guess Appdaemon and the symfonisk controller was too match for it :slight_smile:. Have ordered a Rpi4.
Regarding the other point. I have an Ikea on/off switch/dimmer (not the symfonisk) that I have configured in Phoscon to switch on/off a lamp. And want to use hold-down to increase/decrease TV volume. The below configuration doesn’t work, so I must be doing something wrong.
TV_volume_tradfri_switch:
  module: controllerx
  class: E1743MediaPlayerController
  controller: tradfri_on_off_switch_2
  integration: deconz
  media_player: media_player.samsung_ue46f8000
  1001: hold_volume_up
  1003: release
  2001: hold_volume_down
  2003: release
Hi @Aie,
Have ordered a Rpi4
It will work much better with it. I have the raspi4 with z2m, deconz, appdaemon, MariaDB, MQTT, NGINX, DuckDNS, Samba, and more. I also have ~10 devices and >120 entities, and I haven’t had any issues with it.
You have the configuration almost correct, but you will need to add the mapping attribute like:
  module: controllerx
  integration: deconz
  mapping:
    1003: release
    2003: release
If you remove the mapping part, then the controller will do the following:
  • Click “I” → Play/Pause
  • Click “O” → Next track
  • Hold “I” → Volume up
  • Hold “O” → Volume down
However, if you already using the click for something else, then I recommend you having the above configuration since click (1002 and 2002) are omitted.
Cheers,
Xavi M.
@xaviml, many thanks for creating this, I’ve just moved over to ZHA from Z2M and thought there must be an easier way of doing things than the loads of automations I did have but didn’t realise it could be this simple, obviously at the expense of all your hard work.
Few quick questions that I haven’t found the answers to, probably there but just can’t see them so apologies if it looks like laziness.
First, is there a quick way to reload the config rather than having to restart HA each time I tweak it?
In the config I set up below, it would only work if I added an entity to the top part of the code, in this case another light: light.sams_bedroom at line 6, despite every button having an entity specified for it, is this just how it is or am I missing something?
sams_wall_remote:
  module: controllerx
  class: HueDimmerController
  controller: xx:xx:xx:xx:xx:xx:xx:xx
  integration: zha
  mapping:
    on_short_release:
      - service: light.turn_on
          entity_id: light.sams_bedroom
    off_short_release:
      - service: light.turn_off
    on_short_release$2:
          entity_id: light.ice_block
    off_short_release$2:
    off_long_release:
    up_short_release:
      - service: click_brightness_up
    down_short_release:
      - service: click_brightness_down
    up_hold:
      - service: hold_brightness_up
    down_hold:
      - service: hold_brightness_down
    on_short_release$3:
      - service: scene.turn_on
          entity_id: scene.sam_morning
Lastly, how would I set a button up to cycle through some specific settings on each press like it does for brightness below from a different app-daemon app, I’m thinking a selection of specific colours rather than using ‘click_xycolor_up’ which would go through the lot? …
    off_short_release:
      action_type: cycle
      entity: light.floor_lamp
      parameters:
        - brightness_pct: 33
          kelvin: 3000
        - brightness_pct: 67
          kelvin: 3000
        - brightness_pct: 100
          kelvin: 3000
        - brightness_pct: 0
Many thanks.
Hi @Bobby_Nobble,
I’m glad you find ControllerX useful. I have been in the same place as you, where I had long HA YAML automations to just make a remote control the lights. I will answer you questions one by one.
If you have the standard and default configuration for AppDaemon, every time you save the /config/appdaemon/apps/apps.yaml file, it will reload the configuration. So you don’t need to restart HA every time you change something. The only time you need to reload something is AppDaemon and is when you upgrade or downgrade the ControllerX version.
ControllerX has a base class called Controller where all other controllers inherit from. Under the Controller class you have the type controller (LightController, MediaPlayerController, SwitchController, and CoverController) that the device controllers inherit from. In the case of HueDimmerController is a LightController (check here). This means that this controller is tight to functionality related to lights, and therefore a light attribute is mandatory, otherwise it will not work. Having said this, the advantage of separating the different type of controllers is that you have predefine actions that act to the entities (light, media player, etc). You can see the predefined actions in here. This means that the configuration you placed can be reduced by using the predefined actions:
sams_wall_remote:
  module: controllerx
  integration: zha
  mapping:
    on_short_release: "on" # This is the default behaviour
    off_short_release: "off" # This is the default behaviour
    on_short_release$2:
    off_long_release: # Not sure why you want the lights to be off when releasing after a long hold
    up_short_release: click_brightness_up # This is the default behaviour
    down_short_release: click_brightness_down # This is the default behaviour
    up_hold: hold_brightness_up # This is the default behaviour
    down_hold: hold_brightness_down # This is the default behaviour
    on_short_release$3:
I recommend you checking the comments I left in the configuration since there are some things that don’t make sense. If what you want is to have the Phillips Hue Dimmer switch work with the default mapping (check the device page I linked before), but turn on/off another light when double clicking, then this is what you would need:
sams_wall_remote:
  module: controllerx
  integration: zha
  merge_mapping:
    on_short_release$2:
    on_short_release$3:
Well, this is not 100% configurable, but you can set a color palette yourself and every time you press, it will cycle through that palette instead of the default one. You can read more about it in here (color_wheel attribute). The configuration would look like:
```yaml
sams_wall_remote:
  module: controllerx
  integration: zha
  color_wheel: # These are the color setting in xy format.
    - [0.525, 0.411]
    - [0.167, 0.338]
    - [0.324, 0.329]
  merge_mapping:
    on_short_release$2:
    on_short_release$3:
I hope you find all these answers useful. You also made me realised that the ZHA mapping from Hue Dimmer device page from the documentation is outdated, and needs to be updated. The correct mapping is the one you posted in the configuration (the same as the code). So thank you :smiley:
Regards,
Xavi M.
Thank you so much for the more than full explanation, all makes perfect sense now.
Didn’t think of just trying it after editing, so used to having to reload automations etc to make them active.
The reason for the off_long_release is it seemed the easiest way for him to remember an all off function, it only has a couple of things in the example but will have 6 or so devices when complete, or did you mean why that instead of off_hold, in which case I just used that because I used release for everything else and didn’t think about it further.
The color_wheel solution is perfect for what I wanted thanks :+1:
Was confused by the ZHA mapping in the documentation, probably why I ended up specifying a lot of things that are defaults :grinning:
After all the help you’ve already given it seems a bit rude to ask but do you think there’s potential to support these…
if so, I’m happy to do any leg work that might help?
Many thanks again.
Thank you so much! adding “mapping:” made the trick :slight_smile:
Now I can use the same switch to control a ligth and also lower the TV volume (with hold down) from the kitchen when my kids have it too loud :wink:
Hi @Bobby_Nobble,
This is the magic of AppDaemon, pretty amazing, indeed.
The reason for the off_long_release is it seemed the easiest way for him to remember an all off function, it only has a couple of things in the example but will have 6 or so devices when complete, or did you mean why that instead of off_hold , in which case I just used that because I used release for everything else and didn’t think about it further.
I was concerned because the off_long_release gets called when the hold action is released, so it would make more sense when the hold action is fired (off_hold). In case of the short click, there is an event for when is clicked and for when is released, so time difference is negligible.
Perfect! I am glad :slight_smile:
That probably didn’t help, indeed. I will change this now, thanks! :smiley:
Yes, supporting controllers is easier, you can fill out this ticket stating the events that are fired and which button fires them.
Regards,
Xavi M.
After amending the rest of the set up along the lines of your recommendation I found out the hard way about merge_mapping also calling the off_hold function as it triggered a colour loop that I could only stop by cutting the power to the bulbs. Now it uses off_hold :slight_smile:
The colour wheel works fine using the default on_hold, but so the bulbs could get back to a proper dimmable white I set on_short_release to activate a scene that specifies colour temp. Works well and gives the best of both worlds whilst simple to remember for my lad.
Great news on the new controller, will sort out the necessary.
Many thanks again for all your help.
v4.1.0 is now released :partying_face:
downloads
This minor change does not contain any breaking changes.
Note: Remember to restart the AppDaemon addon/server after updating to a new version.
:video_game: New devices
  • E1766 - add light controller support for ZHA [ #152 ] @choif
  • AC025XX00NJ - add light controller support for ZHA [ #153 ]
Setting this up for the first time, and having trouble with extracting the controller ID. I’m using ZHA and have a E1810 and E1743. When I go to listen for events, I’m not seeing any events come up when I press buttons. I’m sure I’m missing something simple. Any assistance you could provide would be most appreciated!
Assuming you have paired them with ZHA you go to Configuration>Integrations>click on ‘Devices’ within the ZHA panel>click on the device and under ‘Zigbee info’ you’ll see ‘IEEE:’, that’s the controller ID.
Hi, I set up controllerX sucessfuly for the following:
ganglicht_controller:
  module: controllerx
  class: E1810Controller
  controller: sensor.tradfri_remote_action
  integration: z2m
  light: light.wohnzimmerlicht
What I cant get to work is this:
sonos_wohnzimmer_controller:
  module: controllerx
  controller: sensor.tradfri_soundcontroller_1_action
  integration: z2m
  media_player: media_player.wohnzimmer
  delay: 150
  volume_steps: 15
I checked all entities and they are correct, I am pretty stuck where to start with debugging :frowning:
Hi @derfNamttog,
You can check the IEEE following @Bobby_Nobble’s instructions, however, when listening for the zha_event and interacting with your controller, you should see the event messages in there. If you don’t see them, ControllerX will not work since it listens to that event to know the buttons that were pressed or held for example. Have you added your controller successfully with ZHA?
Regards,
Xavi M.
Hi @AndiS,
Seems you are having the same problem as @Hoekeren had recently. The problem was that you are probably using the E1744 controller without the legacy: false option in the devices.yaml. You can see his first post regarding this in here, and then you can follow down the thread to see how to fix the problem and also which tips I gave to him.
Let me know if you have any questions.
Cheers,
Xavi M.
Hi @xaviml,
thanks for coming back to me! This actually did the trick, its working now! whoop whoop :partying_face:
Somehow it is pretty laggy, any tips?
Hi @AndiS,
You are a lucky one, I just added a new FAQ regarding that:
  • FAQ#8 describes the problem you had
  • FAQ#9 describes the problem you are having. Basically, the configuration you currently have listens to HA instead of MQTT.
You can read more about it in the FAQ page.
Let me know if you have any questions :slight_smile:
Regards,
Xavi M.
Okay, so that seems to be my issue. I can’t pair them with ZHA for some reason. How do I put these in pairing mode?
