You just shared your token and you home assistant url, that’s really something you should not make public! Immediately delete your access token and generate a new one!
Your appdaemon.yaml configuration is invalid. Below is an excerpt from my appdaemon.yaml file as a reference.
secrets: /conf/secrets.yaml
logs:
main_log:
filename: /conf/logs/appdaemon.log
error_log:
filename: /conf/logs/error.log
access_log:
filename: /conf/logs/access.log
appdaemon:
time_zone: 'Europe/Zurich'
latitude: !secret latitude
longitude: !secret longitude
elevation: !secret elevation
missing_app_warnings: 1
production_mode: False
app_dir: /conf/apps
plugins:
HASS:
type: hass
namespace: hass
token: !secret appdaemon_token
ha_url: http://192.168.0.5:8123
http:
url: http://192.168.0.5:5050
api:
admin:
For you information, I flagged your post to get it removed. Should this ever happen again, ask a moderator to remove your post as soon as possible and change all the information that got leaked immediately.
your appdaemon.yaml file appears to have fixed my issues.
what does this mean in http://192.168.0.21:5050
tv_sonos_speaker: Entity sensor.ikea_sound_action not found in namespace default
Basically HAdashbaord appears and everything looks good however the controller fails.
I checked HA and it works in there
apps.yaml
tv_sonos_speaker:
module: controllerx
class: E1744MediaPlayerController
sensor: sensor.ikea_sound_action
media_player: media_player.tv_sonos
Either remove the line
namespace: hass
from the appdaemon.yaml or change it to
namespace: default
OK now it is kind of working now and I suspect the issue might be Sonos and the controllerX code
Not working
Volume not working I expect Sonos need to see volume as 0.99 and controllerX uses 99
Play
Working
Skip track
Previous track
Pause
Do you use “debounce” on th z2m config? I have noticed that if debounce option is on?
The code itself just calles the service media_player.volume_up from HA. Does this work from HA?
haha yes removing debounce fixed it
Thanks everyone for all help much it was appreciated! You guys really are the best!!!
Now on to getting HCAS loaded and working.
You are welcome. I am glad it worked. I am working now in some changes that will require to change your configuration for ControllerX a bit. I will keep you updated in this thread.
My only issue is the number of rotions needed to increase to 50% is a lot
That is becauae of the default delay which is 1s, you can add a new entry below media_player
delay: 500
Maybe it will work better for you, you can tweak it so it works best for you.
where can I find the delay: ?
tv_sonos_speaker:
module: controllerx
delay: 500
Sorry, here is the context for the delay
option.
for more context what is the default delay?
You can find the delays depending on the used class in here: https://github.com/xaviml/controllerx/wiki/Supported-controllers
For the E1744MediaPlayerController the default is 1000. Did the delay 500 do something?
lower the number to say 200 makes the rotation jump in 4% at a time instead of 2%
Hello, I am trying to set this up but I have the feeling that I am missing something. Got HA in docker with HACS with AppDaemon. I installed ControllerX and so far so good. Rebooted the whole thing.
I then added this to my configuration:
livingroom_controller:
module: controllerx
class: E1810Controller
sensor: sensor.tradfri_remote_control_action
light: group.inlights
livingroom_dimmer:
module: controllerx
class: ICTCG1Controller
sensor: sensor.tradfri_wireless_dimmer_action
light: light.572060402cf4321abbee
sensor.tradfri_remote_control and sensor.tradfri_wireless_dimmer are the name that I got from the IKEA TradFri integration. Just added _action after that.
And this here that I am not sure I am doing this correctly. Shoud I remove the integration and set up a Zigbee2MQTT integration and therefore I need to install someting like this https://www.zigbee2mqtt.io/ ?
I am confused because the documentation says it does not use Z2M but then I read you can get the name of the entities in Z2M integration.
So far I get this on startup : Setup failed for livingroom_controller: Integration not found.
I then added in my configuration with the home that it would discover devices but no luck.
mqtt:
discovery: true
discovery_prefix: homeassistant
What I am trying to get is event from the buttons so I can trigger actions in automation.
Can you point me in the right direction ?
What should be done on mqtt side ?
Thanks !
What I don’t get is zigbee2mqtt installation send you there this page sends you back to the first one. I understand the best way to get mqtt in HA is to set the mqtt configuration with discovery set to true, but I have no idea how you actually install z2m to be able to do this In your Zigbee2mqtt configuration.yaml
set homeassistant: true
All searches send me to HASSIO only
Every time the volume up/down service from HA is called it changes 1% only?
In order to use the devices you need the device to be integrated either with deCONZ or Zigbee2mqtt, do you have any of this two integrations?
