Controlling an Electric Recliner
Some have 2.4ghz remotes and a 2.4ghz reciever/transmitter is just not available. However a 433.92 one is. It works. The problem is now how to control the sending of RF signals smoothly.
I have made two buttons.
type: horizontal-stack
cards:
  - show_name: true
    show_icon: true
    type: button
    entity: script.backrest_up
    icon: mdi:seat-recline-normal
    hold_action:
      action: perform-action
      perform_action: script.backrest_up
      target: {}
    tap_action:
      action: none
  - show_name: true
    show_icon: true
    type: button
    entity: script.backrest_down
    icon: mdi:seat-recline-extra
    tap_action:
      action: none
    hold_action:
      perform_action: script.backrest_down
      target: {}
The problem is I want to use a slider from 1-100 or just repeat the up and down. Right now I have a script to send the RF signal up or down. It only does this one so I need to repeat it and ideally have a slider control like this:
type: entities
entities:
  - entity: input_number.recliner_input_number
Again I have no idea how to map the slider or how to repeat the command. I know the custom button card can repeat commands but again unsure how to get it to repeat smoothly.\
Found this link but unsure how to format the custom card and whether it can send a repeated rf command.
Ive created an automation with a while loop and no delay but it sends the RF command, stops, then sends it again resulting in a stutter which is very annoying.
This works but it si not smooth at all.. Is there anyway to smooth out the signals being sent?
This just does not work as even reducing the delay to 1ma just results in more commands being sent whilst being held down.
I think a slider form 1-100 may be better, I have no idea how to make a slider from 1 - 100 and integrate it into the control.
type: custom:button-card
hold_action:
  action: toggle
  repeat: 200
There is no point. No matter the control the RF emitter cannot send a constant stream of RF signals so it is GO STOP GO instead of GO GO GO. This leads to a LOT of stuttering in the motor.
Just buy another remote and hook it up manually to an ESP board. Or just use another remote. Even the broadlink apps do the same GO STOP GO and not smooth GO GO GO RF transmission.
So thanks to some excellent troubleshooting from DeSwaggy on the Discord HA forum I can definitely say that the issue is hardware.
The Broadlink RM4 has a hardware limited packet size “we know the RM4’s ceiling is somewhere between 734 and 1462 bytes” and when sending:
“That GO STOP GO is likey it remote.send_command defaults delay_secs to 0.4 seconds between repeats. Your receiver sees 400ms of silence, assumes you released the button, stops the motor. Next repeat starts it again. Your physical remote transmits continuously with no gap, that’s the whole difference.”
“Broadlink packets carry their own repeat count at byte 1. Repeats done inside the packet run on the device itself, back to back, with no trip over the network and no delay_secs between them. Much tighter than num_repeats. python-broadlink · DocSearch MCP”
" Grab your down code from .storage/broadlink_remote_<MAC>_codes,"
“a learned RF code is a fixed-length recording of pulses.”
"There’s no “keep transmitting until I say stop” in the protocol at all, "
However overall it’s the hardware limitation of the packet size. The transmitting packet itself has gaps in it so it will always stutter with the GO STOP GO.:
"So the Broadlink is transmitting near-continuously, the problem is two oversized gaps baked into the recording:
85.7ms near the start
45.7ms at the end
That’s ~130ms of dead air every loop, against a normal inter-frame gap of 9.35ms. Your receiver almost certainly treats that as “button released”."
Even editing the packet itself made no difference but made the movement smoother.
“It’s rebuilt it with both gaps cut to the normal 9.35ms. If it runs smooth for roughly half a second, that’s the cause confirmed, and from there you stack sends for travel, or we build you a longer packet with more frames in one transmission.
And If it still chops, the gap is the Broadlink keying its transmitter between packets, which no amount of editing fixes. ESP32 then.”
" Hold the button and its chip transmits a frame, 9.35ms gap, another frame, gap, another, and it keeps going for as long as the contact is closed. Release and it stops mid-stream. There’s no fixed length because there’s no recording - the button is the duration. The Broadlink can’t do that. It only plays back what it captured, and your capture is a 675ms snapshot of that stream. That’s why hold_secs did nothing, you can’t hold a recording.
The sync gap matters because of how the receiver reads it. Long gap, decide “new transmission”, then decode frames. Shorten that gap and it never recognises a start.
Required part of the pattern, not padding… hence my trimmed version doing nothing."
The end result is it did not work even by modifying the packet.
“More frames should mean longer activation, not invalid. So the failure is more likely transmitter-side: your original payload is 734 bytes, the doubled one 1462, and the RM4 probably won’t accept a packet that size. It never went out at all.”
So the best thing to do is just wire an ESP32 to another remote to get a smooth action without stutters or gaps.
