Original Title: I think I found a bug. Can anyone confirm?
Conversation responses do not play when selecting “Run Actions” from the three dot menu within the edit automation page or using the three dot menu on the action itself. Other actions will run using “Run Actions” but not conversation response.
Can anyone else confirm this? Also, if anyone would like to suggest a better title for this post I’d be happy to change it.
Steps to reproduce:
Create new automation
Add any trigger you want
Add action “Conversation Response”
Save automation
Select “Run Action” from either three dot menu
Nothing happens
Run automation using trigger
“Conversation Response” plays
Edit: Forgot to add my HA version
Core 2025.3.0
Supervisor 2025.03.2
Operating System 14.2
Frontend 20250305.0
Based on the docs this doesn’t really qualify as a bug… it analogous to when templates based on the trigger variable don’t work when you use “Run Action”… if the automation isn’t triggered by a conversation engine, the set_conversation_response has nothing to respond to.
