Hi there. I have created a “copy” of the remote controller of my LED strip to be able to control it from Home Assistant.
The remote controller has 6 buttons to set the brightness: 10%, 20%… 100%. so I followed a guide and created 6 buttons on my ESP32 as a temporary solution.
What I really want is that these 6 buttons to be exposed as a slider with 6 positions (similar to a fan with 3 speeds) and if it is possible, include the on/off button into the “slider”
This is my current yaml code:
remote_transmitter:
pin: GPIO4
carrier_duty_percent: 50%
button:
on_press:
- remote_transmitter.transmit_nec:
address: 0x7F80
command: 0xED12
on_press:
address: 0x7F80
command: 0xE51A
on_press:
address: 0x7F80
command: 0xE11E
on_press:
address: 0x7F80
command: 0xFE01
on_press:
address: 0x7F80
command: 0xFC03
on_press:
address: 0x7F80
command: 0xFB04
on_press:
address: 0x7F80
command: 0xF906
on_press:
address: 0x7F80
command: 0xF807
on_press:
address: 0x7F80
command: 0xF609
on_press:
address: 0x7F80
command: 0xFD02
on_press:
address: 0x7F80
command: 0xF906
Any help will be very much aprreciated.
