jjeb33267
(Justin)
1
Using 3 random helpers configured between 0 and 255 to set the RGB values of a light.
I understand HA defaults sensor values to string.
Cant seem to find how I’d convert these sensors to integer in a way that works without complaining of data types…
action: light.turn_on
metadata: {}
rgb_color:
- { states('sensor.random1')|int(0)}
- { states('sensor.random2')|int(0)}
- { states('sensor.random3')|int(0)}
entity_id: light.tz3210_xz5yasnb_ts0505b_light
Im definitely missing something very simple…
Greatly appreciated!
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
2
Hi Justin,
I made a tool you can use.
Use as-is or look at the code and roll your own with it.
You can find it in HACS.
WallyR
(Wally)
3
In order to get the values from Jinja you need to use double brackets, like {{ and }}
No idea if the rgb_color can be templated though.
