Convert SLZB-06M from TCP(PoE) to USB
I have a decent sized Zigbee mesh running with an SLZB-06M coordinator on my LAN via PoE. I have seen a couple of times the coordinator stop responding due to socket issues. Recent OS updates for the stick reference issues with instability in the socket process, so I was looking to convert to using USB instead. I converted my Thread network that is also using a different SLZB-06M and it was easy, but I cannot see how to do it for ZHA. Is there an easy way to shut down ZHA and tell it to use the appropriate /dev/tty device as the serial port instead of the socket:// device, without repairing the Zigbee devices?
Looking into it some more it appears I should be able to use the Migrate adapter feature and choose to reconfigure my existing radio…? Problem I see now is when I click on Migrate adapter I get an HTTP 500 error. Log is below, any ideas on how to fix this?
Logger: aiohttp.server
Source: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:481
First occurred: 4:42:00 PM (1 occurrence)
Last logged: 4:42:00 PM
Error handling request from 2601:283:5080:e320:d4a7:9c48:69f9:a542
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
    return await handler(request)
  File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 87, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
    response = await handler(request)
  File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
    result = await handler(request, **request.match_info)
  File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
    return await func(self, request, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 272, in post
    return await super().post(request)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 74, in wrapper
    return await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 76, in post
    return await self._post_impl(request, data)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 83, in _post_impl
    result = await self._flow_mgr.async_init(
    ...<2 lines>...
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 316, in async_init
    flow = await self.async_create_flow(handler, context=context, data=data)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3701, in async_create_flow
    return handler.async_get_options_flow(entry)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 875, in async_get_options_flow
    return ZhaOptionsFlowHandler(config_entry)
  File "/usr/src/homeassistant/homeassistant/components/zha/config_flow.py", line 1136, in __init__
    self._radio_mgr.radio_type = RadioType[config_entry.data[CONF_RADIO_TYPE]]
KeyError: 'radio_type'
