I’m trying to convert token expiry to date time stamp.
For example:
expires_at: 1643539008
is equal to
Sunday, 30 January 2022 10:36:48 AM
I’ve rest sensor and I want to convert the expiry to timestamp
- platform: rest
resource: https://xxx
method: POST
username: xxx
password: xxx
authentication: basic
headers:
Auth: API
json_attributes:
- access_token
- expires_at
value_template: >
{% if value_json.access_token is defined %}
{{ THIS IS WHERE I WANT TO DISPLAY CONVERSION }}
{% else %}
KO
{% endif %}
scan_interval: 3600
value_template: >
OK
{% else %}
KO
{% endif %}
scan_interval: 3600
as I was getting 255 character limit error for json value_template with your conversion code added. However, your conversion is working, I just have to create a template to display the value.
Now I need to convert the time back to UTC to fed back into the system to retrieve the data for the duration.
I tried: {{as_timestamp('2022-01-30 21:00')}} but this gives me 1643536800.0
which is not right, any suggestions ?
I was passing the token value to another REST sensor. When I tried to display the expires_at value by time casting the second sensor wasn’t working. Although the token and expires_at were generated. I just found out that in the second sensor the scan_interval was 600 and once I removed that it worked fine
The issue is still the conversion value within the REST sensor value_template.
If I test in the Development template {{ state_attr(‘sensor.my_token’,‘expires_at’) }}
It gives me the right value but in the Development tool the state was None
Then I did {{ as_datetime(value_json.access_token | int) }}
It displays 1970-01-01 00:00:00+00:00
However, it should display the state as 2022-01-30 19:00:00+00:00
based on the expires_at actual value.
