Convert Unavailable value from inverter to zero
Hello there,
im new here and comming from iobroker.
Home Assistant is really great, but I can’t solve one problem. It’s probably just a syntax error.
The photovoltaic system goes into the “unavailable” state at night and the tiles then have an error.
So I want that when a non-numeric value comes, that it is then replaced by “0”.
I also found a code that basically does this correctly - but it adds two sensors. How do I get that for one sensor at a time?
Working:
template:
  - sensor:
    - name: Solar_ohne_0
      unique_id: Solar_ohne_0
      unit_of_measurement: W
      device_class: Power
      state_class: total
      state: >
        {{ float(states('sensor.solartisch_power'),0) + float(states('sensor.balkonkraftwerk_power'),0) }}
This gives me the correct value for both inverters.
But I also want to have each one individually, but I’m too stupid to rewrite it. No matter what I do it doesn’t work.
I thought it goes like this:
template:
  - sensor:
    - name: SolarTisch_ohne_0
      unique_id: SolarTisch_ohne_0
      device_class: Power
      state_class: total
      state: >
        { float(states('sensor.solartisch_power'),0) }
  - sensor:
    - name: SolarBKW_ohne_0
      unique_id: SolarBKW_ohne_0
      device_class: Power
      state_class: total
      state: >
        { float(states('sensor.balkonkraftwerk_power'),0) }
Where is the mistake?
Thank you very much!!
Ouch.
Found the bug myself. Any improvements?
In case anyone needs it, here is the code:
template:
  - sensor:
      device_class: Power
      state_class: total
      state: >
        {{ float(states('sensor.solartisch_power'),0) }}
  - sensor:
      device_class: Power
      state_class: total
      state: >
        {{ float(states('sensor.balkonkraftwerk_power'),0) }}
