Converted my Pull-Chain Ceiling Fan to Z-Wave Fan Controller
Just got done converting my existing ceiling fan to use the GE Z-Wave 3 Speed Fan controller. Was a bit of a pain running new wiring between the fan and the switch box but glad it’s done. Installing the fan controller is essentially the same as a light switch / dimmer, so if you’ve done those before it should be easy. So far working well locally and through Home Assistant.
